Zooz zst10 stick unrecognized
Okay, got my Zooz stick in the mail today. Stuck it in a USB port. Put zwave: in my configuration.yaml. Rebooted the PI (pi 3b+ running hassos, latest everything) and get this:
Error setting up entry Z-Wave (import from configuration.yaml) for zwave
  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 78, in __init__
    raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /zwaveusbstick : ['NoneType: None\\n']"
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 190, in async_setup
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/zwave/__init__.py", line 366, in async_setup_entry
    config_path=config.get(CONF_CONFIG_PATH),
  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 81, in __init__
    raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /zwaveusbstick : [\'Traceback (most recent call last):\\n\', \'  File "/usr/local/lib/python3.7/site-packages/openzwave/option.py", line 78, in __init__\\n    raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /zwaveusbstick : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
I do get a zwave configuration menu item now in configuration but it doesn’t do anything.
Any ideas where I did a duh?
Set the usb_path in the config.
You guys are good! That did it. Thank you.
I’m having the same problem. I’m running HA on a virtual machine with windows 10. When going to the hardware tab there are no available devices in the serial section.
