I could not find the answer by searching the forums - all examples are for trigger not for action. I want to turn on the light (button 5 - big button) after sunset. What I should use for trigger?
Thanks!
Thanks!
The trigger would be sunset, but I think you want to know the action. Your device should have a switch entity, and so you should be able to do switch.turn_on
with that switch entity as the target.
