Hi there,
I wanted to try to integrate an IR remote in HA, so I bought this TuYa ZS06 device witch is supposed to be supported by Z2M.
Now, trying to learn Ir codes with Z2M (using the HA graphic interface), I get different codes at each try, tried with multiple remotes from multiples manufacturer, same strange result.
Do I miss something ? Is my ZS06 broken ? What’s up doc ?
Thanks for your help
Diego
Here are some samples :
Optoma HD131Xe
On
BYIjrhFDAkABA4cGQwLAAUALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwHAG0AH4AsDCfadgiPWCEMC///gAgcCCEMC
BXUjrRFAAkABA4kGQALAAUALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwGAGwGyAkAH4AsDD/2ddSPaCEAC//91I9oIQAI=
BWEj6RE1AkABA6kGNQLAAUALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwHAG0AH4AsDDxaeYSMJCTUC//9hIwkJNQI=
BVgj1BEeAkABBckGHgJgAoADQAtAA0ABQBPAC0AHQANAE0ABQAtAA0ABQAdAF+AHA0ABwBtAB+ALAwc8nlgjDQkeAg==
BWMjyhEtAkABBrYGLQJgAi1gAUALQAPAAUALQBtAB0ADwAFAC0ADwBvgBwFAF0AB4AMjQAvgBwMHPp5jIwsJLQI=
BUQj3BExAkABBLkGMQJoIAEDMQKFAUALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwFAG0BZQAfgCwMHP55EIw8JMQI=
BXYjrxFDAkABA4YGQwKAAQFlAkALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwHAG0AH4AsDBxmediPPCEMC
BZEjsBFAAkABA40GQALAAQKNBoAgAwFAAsABwAtAB0ADwAFAC0ADQAHAB+ALAcAbQAfgCwMPDp6RI8sIQAL//5EjywhAAg==
DU0j7REZAmMCGQLLBhkCQAdAAUALQANAAUATQAvAB0ALQAHgBw9AF0AT4AsDwBtAB+ALAw9Gnk0jAwkZAv//TSMDCRkC
BXAjrhFCAkABA4sGQgLAAUALQAPAAcALQAdAA8ABQAtAA0ABwAfgCwHAG0AH4AsDBx2ecCPRCEIC
OFF
BXsjrxFBAkABA5EGQQLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9AB0ADD0CeeyPLCEEC//97I8sIQQI=
BZIjphE/AkABA5QGPwLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuUBj8CSJ6SI7sIPwI=
BXEjmRE/AkABA48GPwLAAUALQAPAAcALQAdAA8ABQAtAA0ABAo8GgCADQAcBPwJAAcAHQAHgAwtAAcAPQAcLjwY/AkuecSPRCD8C
BZIjkRFEAkABA4cGRALAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuHBkQCIZ6SI9QIRAI=
BY8jrhFCAkABA4sGQgLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuLBkICNp6PI7QIQgI=
BZAjqhFBAkABA4wGQQLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuMBkECSp6QI7wIQQI=
BYgjqRFBAkABA4wGQQLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuMBkECT56II9IIQQI=
BZIjqRE9AkABA5gGPQLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuYBj0CTJ6SI9EIPQI=
BXkjsxFAAkABA5IGQALAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuSBkACJ555I94IQAI=
BZEjthFBAkABA40GQQLAAUALQAPAAcALQAdAA8ABQAtAA0ABQAfAA0ABQAvAAeADC0ABwA9ABwuNBkECRZ6RI7YIQQI=
Enter
BXsjsRFAAkABA44GQALAAUALQAPAAcALQAdAA8ABQAvgCwPgFwHgBzMHW557I9EIQAI=
BYUjrRFPAkABA5IGTwJAAQMYAk8CQAtAA0ALQAHAC0AHQANAF0ADQAvgCwNAG+ATA4AzABigBwlPAmSehSO3CE8C
BZQjsRFAAkABA48GQALAAUALQAPAAcALQAdAA8ABQAvgCwPgFwHgBzMHQJ6UI8wIQAI=
BY4jrRFCAkABA4sGQgLAAUALQAPAAcALQAdAA8ABQAvgCwPgFwHgBzMHT56OI8EIQgI=
Samsung
On/Off
B6oRqhE8ApkG4AED4AsB4BcfQAFAI+APAcAbQAfgCAMCBjwC
B60RrRFCAoYG4AED4AsB4BcfQAFAI+APAcAbQAfgCAMCBkIC
B6oRqhE+ApMG4AED4AsB4BcfQAFAI+APAcAbQAfgCAMCBj4C
Vol up
B6URpRFAAo0G4AED4AsB4Dcf4AMB4ANLwAsHwrSlEaURQALAD0AH4AsBQBfAA+ALAcAbQAfgFwFAI+AEAwIGQAI=
B6MRoxE/Ao4G4AED4AsB4Dcf4AMB4ANLwAsH1LSjEaMRPwLAD0AH4AsBQBfAA+ALAcAbQAfgFwFAI+AEAwIGPwI=
Onkyo
On/Off
BUcjrhE8AkABA4YGPALAAcALQAdAA8ABQAtAA0ABQAdAA0ABQAdAA0ABwAdAAUALQAPAAcALQAdAA8ABB7ucRyPPCDwC
BUUjqRE8AkABA4cGPALAAcALQAdAA8ABQAtAA0ABQAdAA0ABQAdAA0ABwAdAAUALQAPAAcALQAdAA8ABB8CcRSPPCDwC
Enter
BTAjqhE9AkABA4YGPQLAAcALQAfAA0AB4BcLQB9AAcAHQAHgAwtAAcAPQAdAAws9Aj0CYpgwI+oIPQI=
BVQjjxE6AkABA48GOgLAAcALQAfAA0AB4BcLQB9AAcAHQAHgAwtAAcAPQAdAAws6AjoCQJhUI+AIOgI=
