I was able to add the ZWA039 Aeotec Ltd. / aërQ Temperature and Humidity Sensor v2.0 but not sure how to add the entities. (https://devices.zwave-js.io/)
Mine looks way different. I don’t remember needing to do anything special to get all the sensors. Yours is not seeing the device type ZWA009 so thinking you should remove and re-add.
Hey @sighmon, thanks for your reply. It seems there’s something that is always stopping the process…
Can’t find a way to update my Z-Stick 7. You would assume it would be as simple as right-click upgrade firmware but that is not the case. Can you point me in the right direction?
