After update to 1.32.2 the switching of zwave adapters stopped working
Al battery zwave devices stil work and some of the adapters have a build in temp sensor and they are still being reported but switching al of several different brands of zwave power adapters simplely stopped working. ??
What do your logs say?
You would like to see the zwave log ? I wil copy paste
Z-Wave JS
should hide root values: false
2023-10-21T08:46:16.398Z CNTRLR [Node 002] [translateValueEvent: value updated]
commandClass: Multilevel Sensor
endpoint: 0
property: Power
propertyKey: undefined
internal: false
secret: false
event source: undefined
2023-10-21T08:46:16.398Z CNTRLR [Node 002] [~] [Multilevel Sensor] Power: 3.2 => 3.4 [Endpoint 0]
2023-10-21T08:46:16.399Z CNTRLR [Node 002] [translateValueEvent: value updated]
is root endpoint: true
is application CC: true
2023-10-21T08:46:16.400Z DRIVER « [Node 002] [REQ] [ApplicationCommand]
└─[MultilevelSensorCCReport]
type: Power
scale: Watt
value: 3.4
2023-10-21T08:46:18.394Z SERIAL « 0x010c000400020631050422001eff (14 bytes)
2023-10-21T08:46:18.395Z SERIAL » [ACK] (0x06)
2023-10-21T08:46:18.397Z CNTRLR [Node 002] [translateValueEvent: metadata updated]
endpoint: 0
property: Power
internal: false
secret: false
2023-10-21T08:46:18.398Z CNTRLR [Node 002] [Multilevel Sensor] Power: metadata updated [Endpoint 0]
2023-10-21T08:46:18.398Z CNTRLR [Node 002] [translateValueEvent: metadata updated]
2023-10-21T08:46:18.399Z CNTRLR [Node 002] [translateValueEvent: value updated]
endpoint: 0
property: Power
internal: false
secret: false
2023-10-21T08:46:18.400Z CNTRLR [Node 002] [~] [Multilevel Sensor] Power: 3.4 => 3 [Endpoint 0]
2023-10-21T08:46:18.400Z CNTRLR [Node 002] [translateValueEvent: value updated]
2023-10-21T08:46:18.401Z DRIVER « [Node 002] [REQ] [ApplicationCommand]
type: Power
scale: Watt
value: 3
2023-10-21T08:46:20.455Z SERIAL « 0x010c0004000206310504220022c3 (14 bytes)
2023-10-21T08:46:20.455Z SERIAL » [ACK] (0x06)
2023-10-21T08:46:20.456Z CNTRLR [Node 002] [translateValueEvent: metadata updated]
endpoint: 0
property: Power
internal: false
secret: false
2023-10-21T08:46:20.456Z CNTRLR [Node 002] [Multilevel Sensor] Power: metadata updated [Endpoint 0]
2023-10-21T08:46:20.457Z CNTRLR [Node 002] [translateValueEvent: metadata updated]
2023-10-21T08:46:20.457Z CNTRLR [Node 002] [translateValueEvent: value updated]
endpoint: 0
property: Power
internal: false
secret: false
2023-10-21T08:46:20.457Z CNTRLR [Node 002] [~] [Multilevel Sensor] Power: 3 => 3.4 [Endpoint 0]
2023-10-21T08:46:20.458Z CNTRLR [Node 002] [translateValueEvent: value updated]
2023-10-21T08:46:20.458Z DRIVER « [Node 002] [REQ] [ApplicationCommand]
type: Power
scale: Watt
value: 3.4
Stopping logging event forwarder
Starting logging event forwarder at debug level
2023-10-21T08:46:21.894Z SERIAL « 0x01100004002a0a320221740000042f000085 (18 bytes)
2023-10-21T08:46:21.895Z SERIAL » [ACK] (0x06)
2023-10-21T08:46:21.896Z CNTRLR [Node 042] does not support CC Meter - discarding received command...
2023-10-21T08:46:21.897Z DRIVER « [Node 042] [REQ] [ApplicationCommand] [discarded]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 1.071
time delta: 0 seconds
Starting logging event forwarder at error level
Yes logs are necessary else iwete guessing… and please edit your post to encapsulate the log in code block / reformatted text block (its inside that tag on the editor that says < / >
dont but dont see any erros related?
[quote=“NathanCu, post:4, topic:629417”]
[/quote] did put it in < / >
any idears?
well it is solved. shame nobody write about is before.
anyway after a update of home assistant names of zwave devices where empty.
i needed to rename them and now it works
