Hi, looking for some help getting Zwave working on my HASSIO.
I have a Pi3 model b running HASSIO 0.61.1 which was installed following the instructions and works for all the other devices, heating, light, switches etc.
I’ve sucessfully added a Zwave.ME USB1 stick to the Pi by adding the following lines to my configuration.yaml;
zwave:
usb_path: /dev/ttyACM0
network_key: [SECRET]
debug: True
The xml config file zwcfg_0x55555555.xml has been created in the config folder and contains the following;
<?xml version="1.0" encoding="utf-8" ?>I’ve bought some Sensative Strips but when I try and add these as nodes it fails every time, I’ve tried all 3 so it’s unlikely all 3 are broken.
I use the following process;
In HA from the Configurstion - Zwave Manager menu click ‘Add Node’
The USB stick flashes to show its in learn mode and the OZW_Log.txt show this also;
2018-01-20 16:05:31.373 Detail, Queuing (Controller) Add Device
2018-01-20 16:05:31.374 Info, Add Device
2018-01-20 16:05:31.374 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2018-01-20 16:05:31.375 Detail, Notification: ControllerCommand - Starting
2018-01-20 16:05:31.394 Detail,
2018-01-20 16:05:31.394 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2018-01-20 16:05:31.400 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x01, 0x00, 0x00, 0xb9
2018-01-20 16:05:31.402 Detail,
2018-01-20 16:05:31.402 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2018-01-20 16:05:31.404 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2018-01-20 16:05:31.412 Detail, Node001, Expected callbackId was received
2018-01-20 16:05:31.413 Detail, Node001, Expected reply was received
2018-01-20 16:05:31.414 Detail, Node001, Message transaction complete
2018-01-20 16:05:31.415 Detail, contrlr, Removing current message
2018-01-20 16:05:31.415 Detail, Notification: ControllerCommand - Waiting
2018-01-20 16:06:52.640 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x02, 0x00, 0x00, 0xba
2018-01-20 16:06:52.641 Detail,
2018-01-20 16:06:52.641 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2018-01-20 16:06:52.641 Info, ADD_NODE_STATUS_NODE_FOUND
2018-01-20 16:06:52.641 Detail, Notification: ControllerCommand - InProgress
I then put the Sensative Strips into ‘Add’ mode by placing the round magnet at the round end of the strip 3 times within 10 seconds.
The USB stick srops flashing to indicate its complete but the OZW_Log.txt show a failure;
2018-01-20 16:06:56.115 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x07, 0x00, 0x00, 0xbf
2018-01-20 16:06:56.115 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2018-01-20 16:06:56.115 Info, ADD_NODE_STATUS_FAILED
2018-01-20 16:06:56.115 Detail, Removing current message
2018-01-20 16:06:56.115 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2018-01-20 16:06:56.115 Detail, Notification: ControllerCommand - Failed
2018-01-20 16:06:56.120 Detail,
2018-01-20 16:06:56.120 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2018-01-20 16:06:56.270 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x06, 0x00, 0x00, 0xbe
2018-01-20 16:06:56.271 Detail,
2018-01-20 16:06:56.271 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2018-01-20 16:06:56.271 Detail, Node006, Expected reply was received
2018-01-20 16:06:56.271 Detail, Node006, Message transaction complete
2018-01-20 16:06:56.271 Detail, contrlr, Removing current message
2018-01-20 16:06:56.271 Detail, Notification: ControllerCommand - Completed
What am I doing wrong?
