Zwave Automation Timing out
I’ve spent hours on this already and can’t figure out what is going on. I have been adding zwave switches and setting up automations without any issue until now. I add a Zooz Zen71 (node 16) and starting setting up automations for different scenes on the switch to control multiple other zwave switches. The automation to turn on 3 lights(3 up presses) works just fine. but the automation to turn off 3 lights (node 16 and two other nodes) has a massive delay, sometimes 15 seconds or more. I can run the automations manually in home assistant and they work just fine. Only when they are activated by the switch itself is there an issue. I have tried the following so far.
  1. Updated zwave sitck firmware.
  2. Heal network
  3. Heal node 16
  4. removed and re-added node 16 to the zwave network.
  5. changed the automation to use 4 buttons presses instead of 3.
The issue only seems to occur when the automation includes turning off node 16.
Below are the Zwave logs when trying to activate the automation. I Can’t figure out what is going wrong with this switch. Any help would be amazing. Thank you.
2023-03-04T16:50:55.545Z CNTRLR « [Node 016] Received updated node info
2023-03-04 11:50:55.568 INFO Z-WAVE: [Node 016] Value notification: 91-0-scene-002 4
2023-03-04T16:50:55.573Z CNTRLR « [Node 016] received CentralScene notification {
"nodeId": 16,
"ccId": "Central Scene",
"ccCommand": "0x03",
"payload": "0x748402"
2023-03-04T16:50:55.620Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-03-04T16:50:55.624Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:55.640Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:55.662Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:55.718Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:55.828Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:55.855Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.227Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.288Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.350Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.556Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.631Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:56.807Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.056Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.140Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.293Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.320Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.376Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.403Z DRIVER Dropping message with invalid payload
2023-03-04T16:50:57.586Z DRIVER Dropping message with invalid payload:
0x010900a80001090000bee8
2023-03-04T16:50:57.612Z DRIVER Dropping message with invalid payload:
2023-03-04T16:50:57.640Z DRIVER Dropping message with invalid payload:
0x010900a80001090000bfe9
2023-03-04T16:51:15.897Z CNTRLR [Node 016] Timed out while waiting for a response from the node (ZW0201)
2023-03-04 11:51:15.902 INFO Z-WAVE: [Node 016] Value updated: 37-0-currentValue true => false
2023-03-04 11:51:15.910 INFO Z-WAVE: [Node 016] Value updated: 37-0-targetValue true => false
2023-03-04 11:51:16.040 INFO Z-WAVE: [Node 010] Value updated: 38-0-currentValue 99 => 0
2023-03-04 11:51:16.046 INFO Z-WAVE: [Node 010] Value updated: 38-0-targetValue 99 => 0
2023-03-04 11:51:16.380 INFO Z-WAVE: [Node 009] Value updated: 37-0-currentValue true => false
2023-03-04 11:51:16.387 INFO Z-WAVE: [Node 009] Value updated: 37-0-targetValue true => false
2023-03-04 11:51:16.429 INFO Z-WAVE: [Node 009] Value updated: 37-0-currentValue false => false
2023-03-04 11:51:16.436 INFO Z-WAVE: [Node 009] Value updated: 37-0-targetValue false => false
2023-03-04 11:51:16.442 INFO Z-WAVE: [Node 009] Value updated: 37-0-duration 0s => 0s
2023-03-04 11:51:17.013 INFO Z-WAVE: [Node 010] Value updated: 38-0-targetValue 0 => 0
2023-03-04 11:51:17.021 INFO Z-WAVE: [Node 010] Value updated: 38-0-duration 0s => 0s
2023-03-04 11:51:17.027 INFO Z-WAVE: [Node 010] Value updated: 38-0-currentValue 0 => 0
2023-03-04T16:51:17.402Z DRIVER Dropping message with invalid payload
2023-03-04T16:51:18.030Z CNTRLR [Node 016] Timed out while waiting for a response from the node (ZW0201)
2023-03-04 11:51:29.947 INFO Z-WAVE: [Node 016] Metadata updated: 135-0-80-3
2023-03-04 11:51:29.955 INFO Z-WAVE: [Node 016] Value updated: 135-0-80-3 0 => 0
2023-03-04 11:51:29.961 INFO Z-WAVE: [Node 016] Metadata updated: 135-0-80-4
2023-03-04 11:51:29.966 INFO Z-WAVE: [Node 016] Value updated: 135-0-80-4 0 => 0
2023-03-04 11:51:29.972 INFO Z-WAVE: [Node 016] Metadata updated: 135-0-80-5
2023-03-04 11:51:29.976 INFO Z-WAVE: [Node 016] Value updated: 135-0-80-5 0 => 0
UPDATE: So I removed everything and created an automation that uses Zen71. Scene2 (bottom button) pressed 3 times to turn itself off. This seems to be where the delay is caused. It can use a I don’t know what these log errors are indicating. I’m assuming maybe I just have a faulty switch. If I use a different switch to run an automation to turn this one off it works. It seems like it is not sending data back to my zwave stick correctly? Here are the logs from this test.
2023-03-04T17:28:04.480Z CNTRLR « [Node 016] Received updated node info
2023-03-04 12:28:04.519 INFO Z-WAVE: [Node 016] Value notification: 91-0-scene-002 4
2023-03-04T17:28:04.524Z CNTRLR « [Node 016] received CentralScene notification {
"nodeId": 16,
"payload": "0x828402"
2023-03-04 12:28:04.679 INFO Z-WAVE: [Node 009] Value updated: 37-0-currentValue false => false
2023-03-04 12:28:04.686 INFO Z-WAVE: [Node 009] Value updated: 37-0-targetValue false => false
2023-03-04T17:28:05.736Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:05.788Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:05.873Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.381Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.445Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.515Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.616Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.645Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:06.668Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:07.504Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:07.547Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:07.592Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.087Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.176Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.219Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.267Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.299Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.330Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.419Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.499Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.543Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.637Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.702Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:08.755Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.011Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.083Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.108Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.617Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.691Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:09.723Z DRIVER Dropping message with invalid payload
2023-03-04T17:28:21.358Z CNTRLR [Node 016] Timed out while waiting for a response from the node (ZW0201)
2023-03-04 12:28:21.364 INFO Z-WAVE: [Node 016] Value updated: 37-0-currentValue true => false
2023-03-04 12:28:21.372 INFO Z-WAVE: [Node 016] Value updated: 37-0-targetValue true => false
2023-03-04 12:28:21.457 INFO Z-WAVE: [Node 010] Value updated: 38-0-currentValue 0 => 0
2023-03-04 12:28:21.463 INFO Z-WAVE: [Node 010] Value updated: 38-0-targetValue 0 => 0
2023-03-04T17:28:23.481Z CNTRLR [Node 016] Timed out while waiting for a response from the node (ZW0201)
The Light Never turned off.
