Zwave battery as entity
Is it possible to have the zwave battery appear as an entity. That way you wouldn’t need to template the attribute to get the reading. Also by calling zwave.refresh_entity you could call for an update to the battery reading (through COMMAND_CLASS_Battery) without doing a full node refresh which i presume would causes more radio traffic (thus power) then is necessary.
