I ran the latest upgrades for core etc. and would get the main settings page, but not the devices page nor overview - would not load).
I replaced the microSD with the other one (I rotate two uSD’s for backup) and restored the last backup file (I save backups to a cloud server) and got it running.
I then loaded a new uSD and restored the same backup, but zwave would not come up. I got the below error message in the log.
I ran the latest core update with no change.
I read several threads here that say this is due to having the zwave JS core add-on address, but trying to run the ZUI add-on. But I don’t believe I ever set up ZUI and don’t have a reason to. I don’t think this is the issue.
I disabled the zwave JS addon, and it will not restart when choosing ‘start’ from the add-on page. From the Integrations page, ‘enable’ results in the same error. I restarted HA, no change.
The log from the zwave integration shows normal operation.
Any recommendations are appreciated.
Error: Failed setup, will retry
HA core log:
Logger: homeassistant.components.zwave_js
Source: components/hassio/addon_manager.py:381
integration: Z-Wave (documentation, issues)
First occurred: 2:17:26 PM (8 occurrences)
Last logged: 2:26:19 PM
Failed to start the Z-Wave JS add-on:
from zwave log
2024-05-18T18:47:16.237Z CNTRLR « [Node 022] received wakeup notification
2024-05-18T18:47:16.248Z CNTRLR [Node 022] The node is now awake.
2024-05-18T18:47:16.508Z CNTRLR » [Node 022] Sending node back to sleep…
2024-05-18T18:47:16.575Z CNTRLR [Node 022] The node is now asleep.
configuration:
- Core 2024.5.4
- Supervisor 2024.05.1
- Operating System 12.3
- Frontend 20240501.1
