Zwave Climate
I have a zwave thermostat. It controls both heat and cooling. The devices show up in the gui:
When I click on one of these I get this screen:
The problem is the slider for Target Temperature increments in decimal temperatures and I need it to be in whole number steps. I understand the need for decimal steps when using Celsius temperatures, but I’m using Fahrenheit. Is there an easy way to override that slider? Is there another way to add a text entry field that will pass a value to set the thermostat to a different temperature based on that input?
