Hello
I’m using :
computer :
- Z-Wave Plus Aeotec Z-Stick USB Controller (2018)
- Raspberry Pi 3B+ (2018)
software :
- Raspbian GNU/Linux 10
- docker 20.10.18 with homeassistant/home-assistant:latest (2022.9.1)
locks :
- Yale Smart Lock Z-Wave Module (2nd Generation) (2018)
- Yale Keyless Connected Lock Kit (2018)
I don’t use HAssio, I use Docker-Compose
version: '3.8'
services:
homeassistant:
image: homeassistant/home-assistant:latest
container_name: homeassistant
network_mode: host
volumes:
- /usr/share/zoneinfo/Europe/London:/etc/localtime:ro
- /opt/homeassistant:/config
privileged: true
restart: always
healthcheck:
test: "curl --fail --insecure https://localhost:443"
devices:
- /dev/ttyACM0:/dev/ttyACM0
my configuration used to work for 4 years, but now I believe that Home Assistant is managing Z-Wave differently as upgrading Home Assistant broke the config…
Integration error: zwave - Integration 'zwave' not found.
my config :
# for the zwave dongle
zwave:
usb_path: /dev/ttyACM0
# network key is also in options.xml
network_key: "0x18, 0x0A, 0xB8, 0x9A, 0x96, 0xE0, 0x24, 0xA5, 0xE2, 0x5F, 0xAA, 0x5F, 0x82, 0x39, 0xD7, 0x8F"
# ls -l /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Sep 11 18:01 /dev/ttyACM0
and I was using these entities/states for example, which were working well :
zwave.assa_abloy_garden_lock_zwave
states.lock.assa_abloy_garden_lock_status.attributes.lock_status
sensor.assa_abloy_garden_lock_alarm_type
How could I get these back to work ? I need the new Z-Wave JS ?
