Zwave configuration for sleeping devices does not update
basic details here; Zwave - set configuration parameter - how does it work?
but I figured a new thread was in order since I now know how to configure it, now the configuration updating does not work.
so I make a config change on a zwave ‘sleeping’ device and the the log says:
2019-06-22 13:42:38.320 Info, Node087, Value::Set - COMMAND_CLASS_CONFIGURATION - Auto Report Temperature Time - 13 - 1 - 6
2019-06-22 13:42:38.321 Info, Node087, Configuration::Set - Parameter=13, Value=6 Size=1
2019-06-22 13:42:38.321 Detail, Node087, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_CONFIGURATION
2019-06-22 13:42:38.321 Detail, Node087, Queuing (WakeUp) ConfigurationCmd_Set (Node=87): 0x01, 0x0c, 0x00, 0x13, 0x57, 0x05, 0x70, 0x04, 0x0d, 0x01, 0x06, 0x25, 0x56, 0xbf
2019-06-22 13:42:38.322 Detail,
2019-06-22 13:42:38.322 Detail, Node087, Queuing (WakeUp) ConfigurationCmd_Get (Node=87): 0x01, 0x0a, 0x00, 0x13, 0x57, 0x03, 0x70, 0x05, 0x0d, 0x25, 0x57, 0xb8
but the config actually never changes. I have set the config a few times and thought it might just need to wake up or something but it always remains 12.
thanks
That is why the instructions say to manually wake up the device first. It is also why all battery powered zwave devices have a means of waking them up manually.
first I have heard of it, but ok.
