I am new to Home Assistant, coming from OpenHab. I have installed Home Assistant on Ubuntu 20.04 and installed the OpenZWave addon. So far so good.
I plugged in my Homeseer SmartStick+ USB zwave controller (/dev/ttyACM0) and added it to the configuration.
The log shows communication with the nodes, however, after a couple minutes the zwave addon quits with the following log entries:
[20201228 11:43:09.910 CST] [ozw.library] [info]: Info - Node: 0 Stopping DNSThread
[20201228 11:43:11.912 CST] [ozw.library] [debug]: Detail - Node: 53 Removing current message
[20201228 11:43:11.912 CST] [ozw.library] [debug]: Debug - Node: 0 Value Deleted
[20201228 11:43:11.913 CST] [ozw.library] [info]: Info - Node: 0 mgr, Driver for controller /dev/ttyACM0 removed
[20201228 11:43:11.913 CST] [ozw.manager] [debug]: Driver Removed for "/dev/ttyACM0"
[20201228 11:43:11.913 CST] [ozw.manager] [debug]: OZW Serial Port Closed
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: Shutting Down "ozwdaemon" Version: "0.1.0"
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: OpenZWave Version: "1.6.1545"
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: QT-OpenZWave Version: "1.2.0"
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: QT Version: 5.12.5
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: Exit Reason: EXIT_MQTTDISCONNECTED
[20201228 11:43:11.913 CST] [ozw.daemon] [info]: Please consult log messages for specific error messages if any
[20201228 11:43:11.921 CST] [ozw.manager] [info]: New Client WebSocket Connection QHostAddress("::ffff:127.0.0.1")
[20201228 11:43:11.922 CST] [ozw.manager] [warning]: WebSocket Client Error QAbstractSocket::RemoteHostClosedError
[20201228 11:43:11.922 CST] [ozwadmin] [debug]: Remote Connection Status: QTOZWManager::ConnectionErrorState QAbstractSocket::RemoteHostClosedError
In exit
[cont-finish.d] executing container finish scripts...
[cont-finish.d] mqtt.sh: executing...
1609177391: mosquitto version 1.6.8 terminating
1609177391: Saving in-memory database to /data/mosquitto.db.
[cont-finish.d] mqtt.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Thanks, I was able to get connected with a windows openzwave client. I’m still experiencing the same issue though. The log always looks the same. I’m wondering if
is the key? I haven’t really done anything with MQTT yet. Is there an MQTT requirement?
I did read the documentation. I was using the internal MQTT broker and the tests were working from the integration page. I checked the docker containers and noticed a lot of MQTT stops and starts. If I try to install and start Mosquitto I (not surprisingly) get a port conflict. I guess my question should be, is the internal MQTT sufficient or do I need to disable it and install a different broker?
That’s how I did it as well, although not with success. I might rebuild with Debian 10 instead of Ubuntu so I can get rid of the unsupported warnings and try again.
Although, I’m not sure you can just go and remove the MQTT integration if you’re already setup. I think it is determined when the OZW integration is installed.
I did a clean install of Debian 10 instead of Ubuntu 20.04 and installed the Mosquitto addon instead of the broker available in integrations and the zwave addon is now working and stable.
It caused me some issues the other day. I just deleted and installed the ozwave integration and it fixed itself. Had to rename everything which was a pain in the ass but it’s been working fine since.
I caused the issue by attempting to make my own MQTT sensors. Stop trying to fuel the fire it’s childish, it was my own doing. You’re welcome to check out my chat history on discord regarding the issue I created.
