Looks like this started around 10/15 for me. I didn’t see it in the release notes but perhaps I just missed it.
Is there an action item I can take that would reduce the frequency of it going into the jammed state?
What controller do you have (model and firmware numbers matter)
What ZWave Integration are you using?
Hi @NathanCu -
I have the Zooz ZST39LR 800 Series
FW: v1.20
SDK: v7.19.3
113 devices
Using Z-Wave JS UI Addon (option 2 here)
I know things are a bit flaky with zwave devices but I hadn’t seen this sensor before
Any updates on this? I have a similar situation but mine started maybe mid-September. In the process of troubleshooting, I apparently somehow messed up the Aeotec Z-Stick 7 Plus that I had and Aeotec replaced it with a new one. The problem persists for me and I have encountered this with all versions of the firmware from 7.17.2 through 7.19.4.
I use the base ZWave JS for day-to-day and will leverage the ZWave JS UI interface for OTA updates for the controller and system-level configuration settings. Aeotec has offered the idea that the ZWave JS UI installation may be corrupt and is suggested I ‘reinstall’ it but I am wondering if there may be more effective ways to directly troubleshoot the ZWave JS UI install and potentially clear any data that may be corrupt.
Any ideas from anyone? I’ve tried 2 Zooz 800 controllers and no luck. A soft reset on the stick will work for a couple hours but I need to reboot my entire system to get it to last longer than 12 hours.
My issues also started about 2 weeks ago after I updated to the November release.
Zwavejs debug logs from before the failure please
I am very sorry, but I am not sure the best way to upload a log file. If there is a better way, please let me know.
Below is what I just pulled from Zwave JS UI - it is not working right now…
“2023-11-13T21:41:06.245Z CNTRLR » [Node 007] Sending node back to sleep…
2023-11-13T21:41:06.375Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.384Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.394Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.414Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.452Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:06.497Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:06.559Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.579Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.613Z CNTRLR « [Node 007] received wakeup notification
2023-11-13 16:41:06.630 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:06.630 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:06.631 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:06.674Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.708Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.718Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:06.841Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:06.902Z CNTRLR « [Node 003] received wakeup notification
2023-11-13 16:41:06.915 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:06.916 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:06.917 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:06.946 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:06.946 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:06.947 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.009 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.010 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.010 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.091 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.091 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.092 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.115Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:07.152Z CNTRLR « [Node 007] received wakeup notification
2023-11-13 16:41:07.237 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.238 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.238 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.249 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.249 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.250 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.272Z CNTRLR « [Node 003] received wakeup notification
2023-11-13 16:41:07.284 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.284 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.285 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.325 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.326 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.327 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.368 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.369 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.370 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.381 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.382 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.383 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.429Z CNTRLR « [Node 007] received wakeup notification
2023-11-13 16:41:07.463 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.463 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.464 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.506Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:07.531Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:07.564Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:07.613Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:07.623Z CNTRLR « [Node 003] received wakeup notification
2023-11-13T21:41:07.635Z CNTRLR « [Node 003] received wakeup notification
2023-11-13 16:41:07.670 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.670 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.671 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.679Z CNTRLR « [Node 007] received wakeup notification
2023-11-13 16:41:07.692 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.693 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.693 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.703 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.703 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.704 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:07.732 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.733 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.734 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.828Z CNTRLR « [Node 003] received wakeup notification
2023-11-13 16:41:07.864 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:07.865 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:07.866 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:07.890Z CNTRLR « [Node 007] received wakeup notification
2023-11-13T21:41:07.904Z CNTRLR « [Node 003] received wakeup notification
2023-11-13 16:41:07.935 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:07.937 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:07.938 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.046 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.047 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.049 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.165 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.166 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.167 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.177 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.178 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.178 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.274 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.275 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.276 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.288 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.288 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.289 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.317 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.319 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.321 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.328 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.330 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.331 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.402 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.403 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.403 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.413 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.414 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.415 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.428 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.431 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.433 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.445 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.448 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.451 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.480 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.482 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.484 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.489 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.492 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.494 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.508 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.511 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.514 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:08.798 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmType 7 => 7
2023-11-13 16:41:08.800 INFO Z-WAVE: [Node 028] Value updated: 113-0-alarmLevel 255 => 255
2023-11-13 16:41:08.803 INFO Z-WAVE: [Node 028] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13T21:41:09.491Z CNTRLR The controller is no longer jammed
2023-11-13 16:41:09.492 INFO Z-WAVE: Controller status: Controller is Ready
2023-11-13 16:41:09.495 ERROR Z-WAVE-SERVER: Failed to send the command after 5 attempts (ZW0202)
ZWaveError: Failed to send the command after 5 attempts (ZW0202)
at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5240:23)
at Driver.sendCommandInternal (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5445:28)
at Driver.sendCommand (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:5556:15)
at Proxy.set (/opt/node_modules/@zwave-js/cc/src/cc/BinarySwitchCC.ts:138:24)
at Proxy. (/opt/node_modules/@zwave-js/cc/src/cc/BinarySwitchCC.ts:160:16)
at ZWaveNode.setValue (/opt/node_modules/zwave-js/src/lib/node/Node.ts:1150:39)
at NodeMessageHandler.handle (/opt/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:19:43)
at Object.node (/opt/node_modules/@zwave-js/server/dist/lib/server.js:42:92)
at Client.receiveMessage (/opt/node_modules/@zwave-js/server/dist/lib/server.js:125:99)
at WebSocket. (/opt/node_modules/@zwave-js/server/dist/lib/server.js:57:45)
2023-11-13 16:41:09.508 INFO Z-WAVE: [Node 007] Is now asleep
2023-11-13T21:41:09.510Z CNTRLR [Node 007] The node is now asleep.
2023-11-13T21:41:09.527Z CNTRLR The controller is jammed
2023-11-13 16:41:09.528 INFO Z-WAVE: Controller status: Controller is unable to transmit
2023-11-13T21:41:13.590Z CNTRLR The controller is no longer jammed
2023-11-13 16:41:13.592 INFO Z-WAVE: Controller status: Controller is Ready
2023-11-13 16:41:13.595 ERROR Z-WAVE-SERVER: Failed to send the command after 5 attempts (ZW0202)
2023-11-13 16:41:26.117 INFO APP: GET /health/zwave 301 0.398 ms - 191
2023-11-13 16:41:27.647 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:27.647 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:27.648 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 0 => 8
2023-11-13T21:41:27.696Z CNTRLR The controller is jammed
2023-11-13 16:41:27.696 INFO Z-WAVE: Controller status: Controller is unable to transmit
2023-11-13 16:41:27.758 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:27.760 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:27.763 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:28.300 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:28.302 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:28.304 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:28.660 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:28.665 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:28.668 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:29.048 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:29.051 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:29.053 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:29.369 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:29.372 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:29.375 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:29.688 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:29.690 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:29.693 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.179 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.183 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.186 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.219 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.221 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.222 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.295 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.295 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.296 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.452 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.454 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.456 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.499 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.502 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.506 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8
2023-11-13 16:41:30.562 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-13 16:41:30.565 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-13 16:41:30.568 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 8”
Thanks. There are a couple of things going on. First, your controller is getting jammed and the recovery is failing, That could be a bug, or you have soft reset disabled so it can’t recover, or it’s truly jammed.
But, what I’d look at first is the excessive traffic coming from Nodes 28, 66, 23 which look like motion sensors. They are sending lots of updates per second which is going to cause issues. See if you can adjust their configuration so they update less frequently.
When this issue starts to happen, it’s not always the same nodes. It seems random, but there is likely a pattern. Below is a after I rebooted and things were acting normally, about 8 hours later. A soft reset only worked for 30 minutes or so, so I rebooted.
2023-11-14T10:11:16.912Z CNTRLR [Node 031] Timed out while waiting for a response from the node (ZW0201)
2023-11-14 05:11:20.242 INFO APP: GET /health/zwave 301 0.538 ms - 191
2023-11-14T10:11:22.092Z CNTRLR [Node 050] treating BasicCC::Set as a report
2023-11-14 05:11:22.094 INFO Z-WAVE: [Node 050] Value updated: 32-0-currentValue 0 => 255
2023-11-14 05:11:22.105 INFO Z-WAVE: [Node 050] Value updated: 113-0-alarmType 7 => 7
2023-11-14 05:11:22.107 INFO Z-WAVE: [Node 050] Value updated: 113-0-alarmLevel 0 => 255
2023-11-14 05:11:22.109 INFO Z-WAVE: [Node 050] Value updated: 113-0-Home Security-Motion sensor status 0 => 8
2023-11-14 05:11:22.726 INFO Z-WAVE: [Node 003] Value updated: 113-2-alarmType 0 => 0
2023-11-14 05:11:22.730 INFO Z-WAVE: [Node 003] Value updated: 113-2-alarmLevel 0 => 0
2023-11-14 05:11:22.733 INFO Z-WAVE: [Node 003] Value updated: 113-2-Home Security-Motion sensor status 8 => 0
2023-11-14T10:11:32.909Z CNTRLR [Node 049] treating BasicCC::Set as a report
2023-11-14 05:11:32.911 INFO Z-WAVE: [Node 049] Value updated: 32-0-currentValue 0 => 255
2023-11-14 05:11:32.925 INFO Z-WAVE: [Node 049] Value updated: 113-0-alarmType 6 => 6
2023-11-14 05:11:32.926 INFO Z-WAVE: [Node 049] Value updated: 113-0-alarmLevel 0 => 255
2023-11-14 05:11:32.927 INFO Z-WAVE: [Node 049] Value updated: 113-0-Access Control-Door state (simple) 23 => 22
2023-11-14 05:11:32.928 INFO Z-WAVE: [Node 049] Value updated: 113-0-Access Control-Door state 23 => 22
2023-11-14 05:11:32.997 INFO Z-WAVE: [Node 031] Value updated: 38-0-targetValue 20 => 20
2023-11-14 05:11:32.997 INFO Z-WAVE: [Node 031] Value updated: 38-0-currentValue 20 => 20
2023-11-14T10:11:39.052Z CNTRLR [Node 031] Timed out while waiting for a response from the node (ZW0201)
2023-11-14 05:11:50.307 INFO APP: GET /health/zwave 301 0.626 ms - 191
2023-11-14 05:11:52.682 INFO Z-WAVE: [Node 048] Value updated: 67-0-setpoint-1 62 => 61
2023-11-14 05:11:52.824 INFO Z-WAVE: [Node 003] Value updated: 37-1-targetValue true => false
2023-11-14 05:11:52.825 INFO Z-WAVE: [Node 003] Value updated: 37-1-currentValue true => false
2023-11-14 05:11:53.861 INFO Z-WAVE: [Node 003] Value updated: 37-1-currentValue false => false
2023-11-14T10:11:54.741Z CNTRLR [Node 049] treating BasicCC::Set as a report
2023-11-14 05:11:54.741 INFO Z-WAVE: [Node 049] Value updated: 32-0-currentValue 255 => 0
2023-11-14 05:11:54.756 INFO Z-WAVE: [Node 049] Value updated: 113-0-alarmType 6 => 6
2023-11-14 05:11:54.757 INFO Z-WAVE: [Node 049] Value updated: 113-0-alarmLevel 255 => 0
2023-11-14 05:11:54.758 INFO Z-WAVE: [Node 049] Value updated: 113-0-Access Control-Door state (simple) 22 => 23
2023-11-14 05:11:54.759 INFO Z-WAVE: [Node 049] Value updated: 113-0-Access Control-Door state 22 => 23
2023-11-14 05:11:54.842 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-14 05:11:54.842 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-14 05:11:54.843 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 0
2023-11-14 05:11:59.874 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-14 05:11:59.876 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-14 05:11:59.878 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 0 => 8
2023-11-14 05:12:00.036 INFO Z-WAVE: [Node 031] Value updated: 38-0-targetValue 20 => 20
2023-11-14 05:12:00.036 INFO Z-WAVE: [Node 031] Value updated: 38-0-currentValue 20 => 20
2023-11-14T10:12:06.103Z CNTRLR [Node 031] Timed out while waiting for a response from the node (ZW0201)
2023-11-14 05:12:16.844 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-14 05:12:16.845 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-14 05:12:16.847 INFO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 0 => 8
2023-11-14 05:12:16.944 INFO Z-WAVE: [Node 013] Value updated: 37-0-targetValue true => true
2023-11-14 05:12:16.947 INFO Z-WAVE: [Node 013] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:17.084 INFO Z-WAVE: [Node 013] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:20.422 INFO APP: GET /health/zwave 301 1.590 ms - 191
2023-11-14 05:12:22.892 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmType 0 => 0
2023-11-14 05:12:22.894 INFO Z-WAVE: [Node 066] Value updated: 113-0-alarmLevel 0 => 0
2023-11-14 05:12:22.896 INFO Z-WAVE: [Node 066] Value updated: 113-0-Home Security-Motion sensor status 8 => 0
2023-11-14T10:12:35.056Z CNTRLR [Node 045] treating BasicCC::Set as a report
2023-11-14 05:12:35.058 INFO Z-WAVE: [Node 045] Value updated: 32-0-currentValue 0 => 255
2023-11-14 05:12:35.069 INFO Z-WAVE: [Node 045] Value updated: 113-0-alarmType 6 => 6
2023-11-14 05:12:35.072 INFO Z-WAVE: [Node 045] Value updated: 113-0-alarmLevel 0 => 255
2023-11-14 05:12:35.075 INFO Z-WAVE: [Node 045] Value updated: 113-0-Access Control-Door state (simple) 23 => 22
2023-11-14 05:12:35.077 INFO Z-WAVE: [Node 045] Value updated: 113-0-Access Control-Door state 23 => 22
2023-11-14 05:12:35.234 INFO Z-WAVE: [Node 017] Value updated: 37-0-targetValue false => true
2023-11-14 05:12:35.235 INFO Z-WAVE: [Node 017] Value updated: 37-0-currentValue false => true
2023-11-14 05:12:35.931 INFO Z-WAVE: [Node 022] Value updated: 37-0-targetValue false => true
2023-11-14 05:12:35.932 INFO Z-WAVE: [Node 022] Value updated: 37-0-currentValue false => true
2023-11-14 05:12:36.184 INFO Z-WAVE: [Node 069] Value updated: 37-0-targetValue false => true
2023-11-14 05:12:36.187 INFO Z-WAVE: [Node 069] Value updated: 37-0-currentValue false => true
2023-11-14 05:12:36.262 INFO Z-WAVE: [Node 069] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:36.363 INFO Z-WAVE: [Node 020] Value updated: 37-0-targetValue false => true
2023-11-14 05:12:36.366 INFO Z-WAVE: [Node 020] Value updated: 37-0-currentValue false => true
2023-11-14 05:12:36.633 INFO Z-WAVE: [Node 017] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:37.376 INFO Z-WAVE: [Node 022] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:37.890 INFO Z-WAVE: [Node 020] Value updated: 37-0-currentValue true => true
2023-11-14 05:12:44.172 INFO Z-WAVE: [Node 009] Value updated: 37-0-targetValue true => false
2023-11-14 05:12:44.175 INFO Z-WAVE: [Node 009] Value updated: 37-0-currentValue true => false
2023-11-14T10:12:44.975Z CNTRLR [Node 045] treating BasicCC::Set as a report
2023-11-14 05:12:44.976 INFO Z-WAVE: [Node 045] Value updated: 32-0-currentValue 255 => 0
2023-11-14 05:12:44.990 INFO Z-WAVE: [Node 045] Value updated: 113-0-alarmType 6 => 6
2023-11-14 05:12:44.991 INFO Z-WAVE: [Node 045] Value updated: 113-0-alarmLevel 255 => 0
2023-11-14 05:12:44.992 INFO Z-WAVE: [Node 045] Value updated: 113-0-Access Control-Door state (simple) 22 => 23
2023-11-14 05:12:44.993 INFO Z-WAVE: [Node 045] Value updated: 113-0-Access Control-Door state 22 => 23
2023-11-14 05:12:45.271 INFO Z-WAVE: [Node 009] Value updated: 37-0-currentValue false => false
2023-11-14 05:12:49.315 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmType 0 => 0
2023-11-14 05:12:49.316 INFO Z-WAVE: [Node 023] Value updated: 113-0-alarmLevel 0 => 0
2023-11-14 05:12:49.318 INF BBO Z-WAVE: [Node 023] Value updated: 113-0-Home Security-Motion sensor status 8 => 0
2023-11-14 05:12:50.540 INFO APP: GET /health/zwave 301 2.028 ms - 191
What kind of a device were those chatty nodes? Is there config to slow them down?
