Thank you for clarifying that for me. It helps me remember, a little better, just what was going on back when I was setting things up.
I didn’t remember the exact URL - there were other things going on around me at the time and I forgot to take a screenshot of that. My iPad is in the barn, forgot to bring it back, so I can check tomorrow. Odd that I got that error on my iPad but not my iPhone and not in a browser. When I went to Settings->Devices And Services->Integrations->Z-Wave, I got this when I clicked on “Configure:”
All the devices are there when I click “Devices,” but they’re not operable.
The one in the barn is still working and I think it’s updated. Right now I’m not going to press my luck. I’ll get the house system working again, then I’ll remove ZWJS from the barn system.
Personally, I think the one factor that changed had to do with migrating geese and the phase of the Moon…
In other words, I get what you mean. It could be any small factor that created the issue.
Does that include things like authentication keys? The ZWJS add-on has a place to enter those, ZWJSUI does not. (Or maybe it does when you first set it up - don’t remember.) I do mention those because I have some door locks that need those. But since settings are saved on the stick, that explains to me why the settings stay the same from add on to add on.
For now, I just did a quick check and went to add-ons to see what was included. No sign of ZWJS:
It’s late now so I’ll go through the instructions carefully tomorrow. The more I look things over, the more I think I had set everything up to use ZWJSUI in the first place and probably left ZWJS on because I wasn’t completely sure I wouldn’t be using it later. (The more I think about it, the more I think I must have set it up to use ZWJSUI, since I was used to having it in the sidebar and my memory is clear that I went at least one more step than normal for whatever I used. In other words, I know I didn’t use the default add-on.
Is it possible the official add-on, ZWJS, could be installed without it showing up in the add-ons?
What concerns me is what I see in the ZWJSUI logs. These entries are not sequential - you can see that a few posts up, but these are the ones that seem to be dealing with the error or something missing.
2023-01-03 04:49:22.195 WARN Z-WAVE: Zwavejs driver is not ready yet, statistics will be enabled on driver initialization
2023-01-03T09:49:27.450Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
from the controller (ZW0200)
at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts
:3990:23)
at ZWaveController.identify (/opt/node_modules/zwave-js/src/lib/controller
/Controller.ts:713:33)
at Driver.initializeControllerAndNodes (/opt/node_modules/zwave-js/src/lib
/driver/Driver.ts:1208:26)
at Immediate. (/opt/node_modules/zwave-js/src/lib/driver/Driver
.ts:1015:16)
2023-01-03 04:49:27.451 INFO Z-WAVE-SERVER: Server closed
2023-01-03 04:49:27.458 INFO Z-WAVE: Client closed
