I have just started running homeassistant using docker. I used the installer from https://github.com/home-assistant/hassio-build/blob/master/install/hassio_install and now I want to pass a parameter --device to the homeassistant container. From what I understand this is started by the supervisor so where are the settings used to do docker run?
You installed hassio, you don’t manage the container like a normal docker container. Your devices are already passed through. Just use the hardware button and look for the device name.
Thank you!
