I have a zwave network created with “zwave-js-ui: 9.8.2.c09b638”, “zwave-js: 12.4.3”, Aeotec Z-Stick Gen5+, HA 2024.3 in bare metal.
I don’t know in which version started the issue, but every one/two seconds all my entities related to zwave becomes unavailable and 1/2 seconds later became available with the correct values.
I have reinterviewed all nodes, reload discovery elements, updated topics and always the same issue.
Integration is via MQTT Discovery without Z-Wave JS websocket server neither ZWave integration on HA because I need to manage two different zwave networks in same HA installation (This is because I have one zwave network on ground floor and second zwave network on 3rd & 4rd floor, 1st and 2nd floor are from a different neighbor)
Any idea?
There won’t be any zwave logs in HA because you’re using MQTT. If you’re sure there is no problem with the Z-Wave aspect then you’ll need to start looking at MQTT problems, such as:
HA losing connection with MQTT broker
MQTT errors in HA
HA losing connection to broker
If you’re using MQTT discovery, check availability topics of affected sensors, topic may be reporting entity as unavailable
