I’m a couple of days into Home Assistant.
I’m running into an issue where all of my zwave devices status don’t update properly.
If I turn them on/off manually (on device/switch) the state never changes in HA. When I turn them on (or off) using the UI they actual light does what it is supposed to but the UI doesn’t reflect the current state of the light. The UI will show the new state and then immediately go back to it’s previous state, I have to touch it again to have the UI show that the light is off (or on).
I added about 5 different devices GE dimmers, Homeseer dimmers, on/off relay, old plugin dimmer but every device has this behavior. So that leads me to believe the problem lies between home assistant or the dongle I’m using. I’ve reinstalled HA about a dozen times and tried two different zwave sticks that worked with my old setup (homeseer). I guess the problem lies with the way Home Assistant is set up. I’ve also tried adjusting zwave polling interval as suggested here. That didn’t work either.
I’ve pretty much run out of stuff to try, I even asked bing but that didn’t give me anything to try.
Here is the log that I just pulled of me turning the light on with the UI. I only have 2 nodes connected, the USB stick and the plug in dimmer.
2020-12-23 22:51:18.902 Info, Node002, Sending (Send) message (Callback ID=0x2d, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xc9
2020-12-23 22:51:18.909 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 22:51:18.909 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 22:51:18.926 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x2d, 0x00, 0xc4
2020-12-23 22:51:18.926 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2020-12-23 22:51:18.926 Info, Node002, Request RTT 24 Average Request RTT 24
2020-12-23 22:51:18.926 Detail, Expected callbackId was received
2020-12-23 22:51:18.936 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x63, 0xb5
2020-12-23 22:51:18.936 Info, Node002, Response RTT 34 Average Response RTT 43
2020-12-23 22:51:18.936 Info, Node002, Received SwitchMultiLevel report: level=99
2020-12-23 22:51:18.936 Detail, Node002, Refreshed Value: old value=0, new value=99, type=byte
2020-12-23 22:51:18.937 Detail, Node002, Changes to this value are not verified
2020-12-23 22:51:18.937 Detail, Node002, Expected reply and command class was received
2020-12-23 22:51:18.937 Detail, Node002, Message transaction complete
2020-12-23 22:51:18.937 Detail, Node002, Removing current message
2020-12-23 22:51:18.937 Detail, Node002, Notification: ValueChanged
This is the log after turning the light off using UI.
2020-12-23 22:57:48.560 Detail,
2020-12-23 22:57:48.560 Info, Node002, Sending (Send) message (Callback ID=0x30, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x30, 0xd4
2020-12-23 22:57:48.568 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 22:57:48.568 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 22:57:48.584 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x30, 0x00, 0xd9
2020-12-23 22:57:48.585 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x30 received (expected 0x30)
2020-12-23 22:57:48.585 Info, Node002, Request RTT 24 Average Request RTT 24
2020-12-23 22:57:48.585 Detail, Expected callbackId was received
2020-12-23 22:57:48.595 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x42, 0x94
2020-12-23 22:57:48.595 Info, Node002, Response RTT 34 Average Response RTT 36
2020-12-23 22:57:48.595 Info, Node002, Received SwitchMultiLevel report: level=66
2020-12-23 22:57:48.595 Detail, Node002, Refreshed Value: old value=99, new value=66, type=byte
2020-12-23 22:57:48.595 Detail, Node002, Changes to this value are not verified
2020-12-23 22:57:48.595 Detail, Node002, Expected reply and command class was received
2020-12-23 22:57:48.595 Detail, Node002, Message transaction complete
2020-12-23 22:57:48.595 Detail, Node002, Removing current message
2020-12-23 22:57:48.595 Detail, Node002, Notification: ValueChanged
2020-12-23 22:57:49.565 Info, mgr, Refreshing node 2: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-12-23 22:57:49.566 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x31, 0xd5
2020-12-23 22:57:49.566 Info, Node002, Sending (Send) message (Callback ID=0x31, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x31, 0xd5
2020-12-23 22:57:49.573 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 22:57:49.574 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 22:57:49.590 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x31, 0x00, 0xd8
2020-12-23 22:57:49.591 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x31 received (expected 0x31)
2020-12-23 22:57:49.591 Info, Node002, Request RTT 24 Average Request RTT 24
2020-12-23 22:57:49.591 Detail, Expected callbackId was received
2020-12-23 22:57:49.601 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x26, 0x03, 0x21, 0xf7
2020-12-23 22:57:49.601 Info, Node002, Response RTT 34 Average Response RTT 35
2020-12-23 22:57:49.601 Info, Node002, Received SwitchMultiLevel report: level=33
2020-12-23 22:57:49.601 Detail, Node002, Refreshed Value: old value=66, new value=33, type=byte
2020-12-23 22:57:49.601 Detail, Node002, Changes to this value are not verified
2020-12-23 22:57:49.601 Detail, Node002, Expected reply and command class was received
2020-12-23 22:57:49.601 Detail, Node002, Message transaction complete
2020-12-23 22:57:49.601 Detail, Node002, Removing current message
2020-12-23 22:57:49.601 Detail, Node002, Notification: ValueChanged
Can anyone help me out with this?
Sorry about the formatting.
