Zwave error in 0.57.2
i just upgraded to 0.57.2 and i get the following zwave error
2017-11-10 17:38:16 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
  File "/usr/src/app/homeassistant/setup.py", line 194, in _async_setup_component
    component.setup, hass, processed_config)
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 332, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
    future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/zwave/__init__.py", line 269, in setup
    config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
  File "/usr/local/lib/python3.6/site-packages/openzwave/option.py", line 82, in __init__
    libopenzwave.PyOptions.__init__(self, config_path=config_path, user_path=user_path, cmd_line=cmd_line)
  File "src-lib/libopenzwave/libopenzwave.pyx", line 678, in libopenzwave.PyOptions.__init__ (openzwave-embed/open-zwave-master/python-openzwave/src-lib/libopenzwave/libopenzwave.cpp:11181)
libopenzwave.LibZWaveException: "LibOpenZwave Generic Exception : Can't find config directory /config/zwave/"
this did not happen on 0.56.2 so what changed.
Im using docker on pi 3 if that matters, just changed to arm32v7/python:3.6.
What does the zwave: section of your configuration.yaml look like?
Found the issue I had a config_path line when I removed it everything worked again.
Sorry for the mistake.
