Recently I’m getting following error with Z-Wave, when executing any action.
> 2022-01-12 12:19:33.209 ERROR ZWAVE-SERVER: Failed to send the message after 3 attempts (ZW0202)
> ZWaveError: Failed to send the message after 3 attempts (ZW0202)
> at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3390:23)
> at Driver.sendCommand (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3567:28)
> at DoorLockCCAPI.set (/opt/node_modules/zwave-js/src/lib/commandclass/DoorLockCC.ts:292:21)
> at Proxy.DoorLockCCAPI.<computed> (/opt/node_modules/zwave-js/src/lib/commandclass/DoorLockCC.ts:140:15)
> at ZWaveNode.setValue (/opt/node_modules/zwave-js/src/lib/node/Node.ts:867:14)
> at Function.handle (/opt/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:23:44)
> at Object.node (/opt/node_modules/@zwave-js/server/dist/lib/server.js:39:91)
> at Client.receiveMessage (/opt/node_modules/@zwave-js/server/dist/lib/server.js:95:99)
> at WebSocket.<anonymous> (/opt/node_modules/@zwave-js/server/dist/lib/server.js:48:45)
> at WebSocket.emit (node:events:390:28)
I’ve not changed anything (apart from updates) recently.
What can be issue? (Also please let me know if any other log is needed)
