I have been having so many problems with adding Zwave devices and not much luck, only a couple devices I have been able to add. I was going to try the openzwave beta, but I decided not to. I had added the integration but removed it not long after. Things were working fine after I removed the integration but I just added a networkkey in options file, rebooted and now having this issue, trying removing network key and rebooting and still having this issue.
2021-01-04 19:25:36 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave for zwave
File "/usr/local/lib/python3.8/site-packages/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyACM0 : ['NoneType: None\\n']"
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/zwave/__init__.py", line 368, in async_setup_entry
options = ZWaveOption(
File "/usr/local/lib/python3.8/site-packages/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [\'Traceback (most recent call last):\\n\', \' File "/usr/local/lib/python3.8/site-packages/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /dev/ttyACM0 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
2021-01-04 19:11:20.421 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xe723b2c4
2021-01-04 19:11:21.421 Info, mgr, Driver for controller /dev/ttyACM0 pending removal
2021-01-04 19:11:21.421 Detail, Notification: DriverRemoved
2021-01-04 19:11:21.421 Always, ***************************************************************************
2021-01-04 19:11:21.421 Always, ********************* Cumulative Network Statistics *********************
2021-01-04 19:11:21.421 Always, *** General
2021-01-04 19:11:21.421 Always, Driver run time: . . . 1 days, 20 hours, 36 minutes
2021-01-04 19:11:21.421 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 609
2021-01-04 19:11:21.421 Always, Total messages successfully received: . . . . . . . . . . 609
2021-01-04 19:11:21.421 Always, Total Messages successfully sent: . . . . . . . . . . . . 77
2021-01-04 19:11:21.421 Always, ACKs received from controller: . . . . . . . . . . . . . 143
2021-01-04 19:11:21.421 Always, *** Errors
2021-01-04 19:11:21.421 Always, Unsolicited messages received while waiting for ACK: . . 0
2021-01-04 19:11:21.421 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, CANs received from controller: . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, NAKs received from controller: . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
2021-01-04 19:11:21.421 Always, Messages dropped and not delivered: . . . . . . . . . . . 16
2021-01-04 19:11:21.424 Info, mgr, Driver for controller /dev/ttyACM0 removed
2021-01-04 19:11:22.424 Error, mgr, Manager::GetDriver failed - Home ID 0xe723b2c4 is unknown
2021-01-04 19:11:22.439 Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
2021-01-04 19:11:22.439 Info, mgr, GetSendQueueCount() failed - _homeId -417090876 not found
