I installed home assistant on a raspberry pi with a zwave Razberry2 module.
Here is what I installed for my tests:
OpenZWave + Mosquitto brocker
Qubino zwave din rail dimmer (ZMNHSD01)
Push switch
Bulb.
I don’t get any feedback when I flip the switch.
When I press the switch, the bulb lights up but HA indicates that it is off.
When I click in HA to turn on the bulb, it’s OK. The bulb is on and HA says it is on. If I turn it off with the switch, HA keeps saying the bulb is on!
Then the physical switch is not sending an update to ozw and thus not hass.
this can be multiple things:
1 - defective item
2 - incorrect “lifeline” to controller
3 - some sort of configuration parameter you need to set
4 - firmware issue on your qubino (unlikely)
5 - not a proper integration in ozw (likely :-()
hello has someone found a solution to get a status feedback from the Qubino module with the physical switches? I cannot find a solution despite my research. it seems to work under jeedom, so i think there is a solution with hass. but which ?
