Zwave fibaro sensor problem
Good evening I have a bit of problems with zwave fibro sensors fgms-001, my system always looks at me in initialization, I also tried to access the ozwzwave panel but did not even let me make any changes. I use an aeotec usb stick. somebody can help me thank you
See the Note here:
Battery powered devices need to be awake before you can use the Z-Wave control panel to update their settings. How to wake your device is device specific, and some devices will stay awake for only a couple of seconds. Please refer to the manual of your device for more details.
What you’re reporting is perfectly normal until the device wakes. Similarly it won’t take configuration changes unless it’s awake.
