I have two binary sensors associated to the Gen 5 Z Wave stick. I used the AIO installer originally. Everything works perfectly during the day. I go to sleep and then nothing works. Here is the error message when I restart home assistant. I think it goes away once I reboot RPI. (To test in a second - just tested, hard reboot of RPI fixes it and sensors are recognized) The only thing I can think of is that the automation of soft reset and heal network overnight somehow breaks it. I’ll remove these automations and test it tonight.
16-06-23 06:49:47 homeassistant.bootstrap: Error during setup of component zwave
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py”, line 157, in _setup_component
if not component.setup(hass, config):
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/zwave.py”, line 200, in setup
default_zwave_config_path),)
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : ['Traceback (most recent call last):\n', ' File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init\n raise ZWaveException(u"Can\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n', ' File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception\n return list(_format_exception_iter(etype, value, tb, limit, chain))\n', ' File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter\n for value, tb in values:\n', ' File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain\n context = exc.context\n', “AttributeError: 'NoneType' object has no attribute 'context'\n”]’
