Since few weeks (don’t know exactly when or after what changes) , my Zwave network (or the add-on) just “freezes” , nothing works anymore.
What I see in the log is this:
' at Proxy.set (/usr/src/node_modules/@zwave-js/cc/src/cc/BinarySwitchCC.ts:138:24)\n' +
' at Proxy.<anonymous> (/usr/src/node_modules/@zwave-js/cc/src/cc/BinarySwitchCC.ts:160:16)\n' +
' at ZWaveNode.setValue (/usr/src/node_modules/zwave-js/src/lib/node/Node.ts:1139:39)\n' +
' at NodeMessageHandler.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:20:43)\n' +
' at Object.node (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:42:96)\n' +
' at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:119:99)\n' +
' at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:51:45)'
Z-Wave error ZWaveError: The node did not respond after 3 attempts, it is presumed dead (ZW0202)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4889:23)
at Driver.sendCommandInternal (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5091:28)
at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5202:15)
at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:51:45) {
code: 202,
context: undefined,
transactionSource: ' at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4889:23)\n' +
' at Driver.sendCommandInternal (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5091:28)\n' +
' at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:5202:15)\n' +
2023-09-06T13:11:20.879Z CNTRLR [Node 055] Timed out while waiting for a response from the node (ZW0201)
2023-09-06T13:11:33.546Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2023-09-06T13:11:33.650Z CNTRLR The controller response indicated failure after 2/3 attempts. Scheduling next
try in 1100 ms.
2023-09-06T13:11:42.789Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-06T13:12:12.794Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-06T13:13:09.284Z CNTRLR [Node 010] The node did not respond after 1 attempts, it is presumed dead
Z-Wave error ZWaveError: The node did not respond after 1 attempts, it is presumed dead (ZW0202)
code: 202,
context: undefined,
2023-09-06T13:14:00.022Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-06T14:02:27.181Z CNTRLR [Node 220] Timed out while waiting for a response from the node (ZW0201)
2023-09-06T14:03:04.895Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
rk Management Proxy is not implemented (ZW0303)
2023-09-06T14:03:05.024Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:05.044Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:05.123Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:05.193Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:05.276Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:05.995Z DRIVER Dropping message because it could not be deserialized: The command class Netwo
2023-09-06T14:03:20.765Z CNTRLR [Node 020] The node did not respond after 3 attempts. It is probably asleep, m
oving its messages to the wakeup queue.
2023-09-06T14:03:54.868Z CNTRLR [Node 219] The node did not respond after 3 attempts. It is probably asleep, m
2023-09-06T14:04:23.685Z CNTRLR [Node 012] The node did not respond after 3 attempts. It is probably asleep, m
2023-09-06T14:04:50.772Z CNTRLR [Node 220] The node did not respond after 3 attempts. It is probably asleep, m
2023-09-06T14:04:54.204Z CNTRLR [Node 072] Timed out while waiting for a response from the node (ZW0201)
2023-09-06T14:04:58.585Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2023-09-06T14:05:25.733Z CNTRLR [Node 210] The node did not respond after 3 attempts. It is probably asleep, m
2023-09-06T14:05:26.925Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2023-09-06T14:05:27.031Z CNTRLR The controller response indicated failure after 2/3 attempts. Scheduling next
try in 1100 ms.
I have no idea what is happening here… anyone ?
