I am trying to work on a fresh (manual) install after I borked my old system, but I can’t get Z-wave setup properly. I have followed all the install instructions in the docs, but I can’t get rid of the below error. Any ideas or advice?
Log Details (ERROR)
Tue Mar 20 2018 20:56:10 GMT-0400 (EDT)
Error during setup of component zwave
File “/srv/homeassistant/lib/python3.5/site-packages/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Can’t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: “Zwave Generic Exception : Can’t write to device /dev/ttyACM0 : [‘NoneType: None\n’]”
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 148, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/init.py”, line 275, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File “/srv/homeassistant/lib/python3.5/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : ['Traceback (most recent call last):\n', ' File “/srv/homeassistant/lib/python3.5/site-packages/openzwave/option.py”, line 75, in init\n raise ZWaveException(u"Can\'t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n', 'openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t write to device /dev/ttyACM0 : [\'NoneType: None\\\\n\']”\n']’
Yeah, I am using the Aeotec Z Stick. I have a backup of the old system (0.46.1) but I wanted to update given the need for Python 3.6. The Stick works on the old install, but not the fresh version
I went with the manual install. It was my understanding that when you add the Z-wave component it installs all the necessary dependencies. I also made sure to use the dialout command mentioned in the Docs to give to my ZStick since I am running homeassistant as the user
LINUX (EXCEPT HASS.IO)
On Linux platforms (other than Hass.io) there is one dependency you will need to have installed ahead of time (included in systemd-devel on Fedora/RHEL systems):
$ sudo apt-get install libudev-dev
On Python 3.6 you may also have to install libpython3.6-dev, and possibly python3.6-dev.
Also. Did you do this?
RASPBERRY PI
On Raspberry Pi you will need to enable the serial interface in the raspi-config tool before you can add Z-Wave to Home Assistant.
I did already try the install libudeb-dev, but it came up as already installed. The other 3.6 libs came up with an error saying the package was unavailable. I did test my homeassistant user to see if it included dialout, and this is what it was showing
id homeassistant
uid=999(homeassistant) gid=996(homeassistant) groups=996(homeassistant),20(dialout)
So I think that should be good, right? Here is my config entry for zwave
OK, I did try that, and I was getting the same error, but maybe I’ll try one of those different config paths. Strange that it’s saying that it can’t write to the stick though? Just so I can compare, what does you prompt say when you enter
I followed the install instructions in the docs, but I am getting the same error and have tried both USB path ttyACM0 & ttyAMA0.
I am running raspberry pi in a virtual environment with user homeassistant, and I have added it to the dialout.
What steps did you take for you to get the zwave usb stick working?
By the way, the zwave USB stick is *Zooz Z-Wave Plus S2 stick ZST10
