Hi There - brand new and just starting a setup of ras pi 3 B - also have a brand new Aeotec zstick gen 5
I’m having no luck getting zwave working see attached. I tried both /dev/tty entries and the one that says ACM0 is the only one that appears when I plug the zstick in.
It turned out my configuration.yaml file needed the /dev/serial/by-id/ path and not the /dev/tty path. In another post the issue was the Aeotec Z- Stick Gen 5 seemed to toggle from one /dev/tty path to another on boot. Likely what happened to me as it fixed the issue.
