Hi!
I try to install zwave on Hass.io. The manual https://home-assistant.io/hassio/zwave/ says:
If you need GPIO on raspberry-pi3 for you Z-Wave module add follow line into config.txt:
dtoverlay=pi3-miniuart-bt
But where is the config.txt file and how can I get access to the file?
Thanks for your help
