I have read few old topics on this subject but still cannot get my AEOTEC USB stick to work on my HA (Home Assistant Core on Docker) on PI CM3+
Could someone please help me, advice on how to resolve
This is my config.
Hers is the OZW Log.
2020-06-04 07:54:52.179 Always, OpenZwave Version 1.4.3469 Starting Up
2020-06-04 07:55:00.819 Info, Setting Up Provided Network Key for Secure Communications
2020-06-04 07:55:00.820 Info, mgr, Added driver for controller /dev/zwave
2020-06-04 07:55:00.820 Info, Opening controller /dev/zwave
2020-06-04 07:55:00.820 Info, Trying to open serial port /dev/zwave (attempt 1)
2020-06-04 07:55:00.821 Info, Serial port /dev/zwave opened (attempt 1)
2020-06-04 07:55:00.823 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-04 07:55:00.823 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-04 07:55:00.823 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-04 07:55:00.823 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-04 07:55:00.824 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-04 07:55:00.824 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-04 07:55:00.828 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-06-04 07:55:00.828 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-06-04 07:55:00.828 Info, contrlr, Static Controller library, version Z-Wave 4.54
2020-06-04 07:55:00.829 Detail, Node045, Expected reply was received
2020-06-04 07:55:00.829 Detail, Node045, Message transaction complete
2020-06-04 07:55:00.829 Detail, contrlr, Removing current message
2020-06-04 07:55:00.829 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-04 07:55:01.829 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-04 07:55:01.830 Detail, contrlr, Removing current message
2020-06-04 07:55:01.830 Detail, contrlr, Notification: Notification - TimeOut
2020-06-04 07:55:01.831 Detail,
2020-06-04 07:55:01.831 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-04 07:55:02.333 Warning, WARNING: 500ms passed without reading the rest of the frame…aborting frame read
2020-06-04 07:55:02.333 Warning, WARNING: Out of frame flow! (0x28). Sending NAK.
2020-06-04 07:55:02.334 Warning, WARNING: Out of frame flow! (0x04). Sending NAK.
2020-06-04 07:55:02.339 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-06-04 07:55:02.339 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-06-04 07:55:02.339 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-06-04 07:55:02.339 Info, contrlr, The PC controller is a primary controller.
2020-06-04 07:55:02.339 Detail, Node215, Expected reply was received
2020-06-04 07:55:02.340 Detail, Node215, Message transaction complete
2020-06-04 07:55:02.340 Detail, contrlr, Removing current message
2020-06-04 07:55:02.340 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-04 07:55:02.341 Detail, Unsolicited message received while waiting for ACK.
2020-06-04 07:55:02.342 Detail, contrlr, Received: 0x01, 0x01, 0x00
2020-06-04 07:55:02.342 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2020-06-04 07:55:02.343 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-04 07:55:02.345 Detail, Unsolicited message received while waiting for ACK.
2020-06-04 07:55:02.350 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0xfb, 0x67, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa, 0x88, 0x4f, 0x1f, 0x00, 0x9f, 0x7d, 0xa0, 0x00, 0x80, 0x86, 0x00, 0xe8, 0x73, 0x0e, 0x00
2020-06-04 07:55:02.350 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2020-06-04 07:55:02.351 Warning, WARNING: Out of frame flow! (0x81). Sending NAK.
2020-06-04 07:55:02.352 Warning, WARNING: Out of frame flow! (0x7d). Sending NAK.
2020-06-04 07:55:02.353 Warning, WARNING: Out of frame flow! (0x00). Sending NAK.
2020-06-04 07:55:03.354 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-04 07:55:03.354 Detail, contrlr, Removing current message
2020-06-04 07:55:03.354 Detail, contrlr, Notification: Notification - TimeOut
2020-06-04 07:55:03.355 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-04 07:55:13.355 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-06-04 07:55:13.355 Detail, contrlr, Removing current message
2020-06-04 07:55:13.355 Detail, contrlr, Notification: Notification - TimeOut
