Zwave Integration
I just installed the Zwave integration, though it recognizes my zooz ZST10 Z-Wave plus USB stick and my garage door opener; however, it doesn’t show whether my garage door is open or closed.
At this point I’m not sure what I’m doing wrong as documentation seems to be dated.
Also OpenWave which won’t install saying it is not compatible with your platform. Has it been phased out?
Even with the ZWave integration, do I still need configuration.yaml entries? Normally installing the integration negates needing configuration.yaml entries.
I would appreciate any advice.
Is this a cover entity? Did you add the node securely?
This addon is for 0.110.0 and the OZW integration, which is in beta and is a new alternative z-wave implementation.
No, unless you need to set some advanced configuration options.
Yes it should be a cover, but it isn’t coming up that way. I tried adding the node securely, but didn’t install; just sat and spun and did not get confirmation with the garage controller that it paired.
When I installed the integration, I thought that it said to leave the security code blank to randomly generate one. Is there a way to see if a secure key was indeed generated?
Just noted my USB stick isn’t seen as ZWave Plus, see below
node_id: 1
node_name: Zooz ZST10 S2 Z-Wave Plus USB Stick
manufacturer_name: Zooz
product_name: ZST10 S2 Z-Wave Plus USB Stick
query_stage: Complete
is_awake: true
is_ready: true
is_failed: false
is_info_received: true
max_baud_rate: 40000
is_zwave_plus: false
I have two types of Z-Wave stick, neither of then state that they are z-wave plus yet both acted on the network.
Thinking about this I’m not sure they need to be. They receive updates from plus items they issue commands when required, the plus bit was just to implement the notifiaction of status change which was part of an expired patent.
Do I need to uninstall the integration and start over or is there another way to fix this? My Garage Door doesn’t not seem to want to install as a secure node though I was able to do so with a door/window sensor. The garage door comes up as an unknown node. It only installs if I just do an “add node” but then it doesn’t let me know if the door is up or down. It also won’t let me control the garage door.
Any suggestions.
