Today i was moving from a unsuported Ubunutu installation to the HassOS version.
I made a full snapshot and used this to recover everything within the clean HassOS instal.
Everything seems the be working fine, except the Z-Wave JS integration, it tells me : Retrying setup: Z-Wave JS Server version is incompatible: 1.2.1 a version is required that supports at least api schema 4
when i click at the devices the all show up, and seems to be working fine, but how to solve this error ?
Hey there, everyone…
My problem w/ Z-wave commenced when I had to rebuild from fresh scratch on a Raspberry Pi4B. Followed all the instructions for the initial install, added the add-ons from the previous setup which was on a RPi3B+. All is good except for the z-wave stuff.
What I have since discovered is that the initial installation has marked the filesystem as read-only, thus making the required files and folders not present. Also, the system shows /dev/ttyAMA0 present regardless of whether my Aeotec Z-stick Gen5 is plugged in or not.
Not being a linux-savvy person, I could use some guidance in how to set my filesystem read/write. Putty’s set up as is the terminal/ssh addon and as I said, all works as I would like. Fortunately, I’ve got a Samsung SmartThings hub which handles both zigbee and z-wave. If not for this, I’d really be hosed
okay but all add-on are the most recent ones , so how to update these again ?
I already tried to re-install the Z-Wave JS (after uninstall) , and installed the ZWaveJS2MQTT , but still the same error
Well, after collecting information via dmesg, I discovered that this installation of HassIO uses SquashFS for the root filesystem, which I learned also is interently read-only. I found no errors related to the sd card, a brand-new scandisk 32Gb device.
So, unless there’s a way to change this behavior, I cannot use the Z-wave JS integration or any of the z-wave addons. The system will not detect the presence of the z-wave stick.
That’s the Bluetooth of the Pi 4. You probable have an older Aeotec stick that requires use of a non-powered USB 2.0 hub to actually work, hence it not working at this point.
whatever i did, this doesnt help , still the : Retrying setup: Z-Wave JS Server version is incompatible: 1.2.1 a version is required that supports at least api schema 4
Using the Zwave JS add-on, so is there a way to upgrade this ?
