Zwave invalid configuration
Hi I updated to the latest version of openhab and I’m getting error below.
I using a Pi4. with Nortek zwave/zigbee stick. I have a number of zwave devices mainly lights that I cant access now.
Home Page Notification
Invalid config
The following integrations and platforms could not be set up:
  • zwave
    Please check your config.
Error when I run "Check Configuration"
Configuration validation
Validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid
Configuration invalid
Invalid config for [zwave]: [binary_sensor] is an invalid option for [zwave]. Check: zwave->zwave->binary_sensor. (See /config/configuration.yaml, line 14).
Move lines 17 through 19 left two spaces. Also please don’t post images of YAML, paste it in your message and format it as a code block (three backticks ``` above and below)
@Tediore sorry about that.
Thanks for the guidance!
No prob, glad you got it working.
