Ive been having below errors since update to 2021.8 version
I downgrade to 2021.7 version but problem is persisting
restart will likely fix but problem is this is now occuring daily and multiple times throughout day
Info, Node073, Sending (Send) message (Callback ID=0xcb, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=73): 0x01,
Detail, Node073,
Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
Error, Node073, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Info, Node048, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
Detail, Node048, Refreshed Value: old value=255, new value=255, type=byte
Detail, Node048, Changes to this value are not verified
Detail, Node048, Notification: ValueChanged
Info, Node048, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
Info, Node048, SwitchMultilevel::Set - Setting to level 0
Info, Node048,
Duration: Default
Detail, Node048, Queuing (Send) SwitchMultilevelCmd_Set (Node=48): 0x01, 0x0b, 0x00, 0x13, 0x30, 0x04, 0x26, 0x01, 0x00,
Detail, Node048, Queuing (Send) SwitchMultilevelCmd_Get (Node=48): 0x01, 0x09, 0x00, 0x13, 0x30, 0x02, 0x26, 0x02, 0x25,
Info, Node057, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 3 - False
Info, Node057, SwitchBinary::Set - Setting node 57 to Off
Detail, Node057, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Set (Node=57): 0x01, 0x0e, 0x00,
Detail, Node057, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=57): 0x01, 0x0d, 0x00,
Detail, Node042,
Received: 0x01, 0x0a, 0x00, 0x04, 0x10, 0x2a, 0x04, 0x30, 0x03, 0xff, 0xff, 0xfc
Detail,
Info, Node042, Received SensorBinary report: Sensor:255 State=On
Detail, Node042, Refreshed Value: old value=false, new value=true, type=bool
Detail, Node042, Changes to this value are not verified
Detail, Node042, Notification: ValueChanged
Detail, Node042,
Detail,
Detail, Node042, Refreshed Value: old value=true, new value=true, type=bool
Detail, Node042,
Detail,
Info, mgr,
Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
Detail, Node051, Queuing (Send) SwitchMultilevelCmd_Get (Node=51): 0x01, 0x09, 0x00, 0x13, 0x33, 0x02, 0x26, 0x02, 0x25,
Detail, Node042,
0x09, 0x00, 0x13, 0x49, 0x02, 0x26, 0x02, 0x25, 0xcb, 0x64
0xff, 0x25, 0x0d, 0x23
0x0e, 0xd8
0x13, 0x39, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x0f, 0xbc
0x13, 0x39, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x10, 0xa2
0x13, 0x39, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x11, 0xa2
0x13, 0x39, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x12, 0xa0
0x13, 0x39, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x13, 0xa0
0x13, 0x39, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x14, 0xa6
0x13, 0x39, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x15, 0xa6
0x13, 0x39, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x16, 0xa4
0x17, 0xc2
Detail,
Info, mgr,
Refreshing node 48: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
Detail, Node048, Queuing (Send) SwitchMultilevelCmd_Get (Node=48): 0x01, 0x09, 0x00, 0x13, 0x30, 0x02, 0x26, 0x02, 0x25, 0x18, 0xce
Info, mgr,
Detail, Node051, Queuing (Send) SwitchMultilevelCmd_Get (Node=51): 0x01, 0x09, 0x00, 0x13, 0x33, 0x02, 0x26, 0x02, 0x25, 0x19, 0xcc
Info, mgr,
Detail, Node048, Queuing (Send) SwitchMultilevelCmd_Get (Node=48): 0x01, 0x09, 0x00, 0x13, 0x30, 0x02, 0x26, 0x02, 0x25, 0x1a, 0xcc
Detail, Node057, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Set (Node=57): 0x01, 0x0e, 0x00, 0x13, 0x39, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00, 0x25, 0x1b, 0xa8
Detail, Node057, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=57): 0x01, 0x0d, 0x00, 0x13, 0x39, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x1c, 0xae
Error, Node073, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node073, Removing current message
Detail, Node073, Notification: Notification - TimeOut
Detail,
Info, Node050, Sending (Send) message (Callback ID=0xcc, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=50): 0x01, 0x09, 0x00, 0x13, 0x32, 0x02, 0x26, 0x02, 0x25, 0xcc, 0x18
Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node050, Removing current message
Detail, Node050, Notification: Notification - TimeOut
Detail,
Info, Node066, Sending (Send) message (Callback ID=0xcd, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=66): 0x01, 0x09, 0x00, 0x13, 0x42, 0x02, 0x26, 0x02, 0x25, 0xcd, 0x69
Error, Node066, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node066, Removing current message
Detail, Node066, Notification: Notification - TimeOut
Detail,
Info, Node092, Sending (Send) message (Callback ID=0xce, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=92): 0x01, 0x09, 0x00, 0x13, 0x5c, 0x02, 0x26, 0x02, 0x25, 0xce, 0x74
Error, Node092, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node092, Removing current message
Detail, Node092, Notification: Notification - TimeOut
Detail,
Info, Node071, Sending (Send) message (Callback ID=0xcf, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=71): 0x01, 0x09, 0x00, 0x13, 0x47, 0x02, 0x26, 0x02, 0x25, 0xcf, 0x6e
Error, Node071, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node071, Removing current message
Detail, Node071, Notification: Notification - TimeOut
Detail,
Info, Node091, Sending (Send) message (Callback ID=0xd0, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=91): 0x01, 0x09, 0x00, 0x13, 0x5b, 0x02, 0x26, 0x02, 0x25, 0xd0, 0x6d
Error, Node091, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node091, Removing current message
Detail, Node091, Notification: Notification - TimeOut
Detail,
Info, Node050, Sending (Send) message (Callback ID=0xd1, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=50): 0x01, 0x09, 0x00, 0x13, 0x32, 0x02, 0x26, 0x02, 0x25, 0xd1, 0x05
Detail,
Info, Node047, Sending (Send) message (Callback ID=0xd2, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=47): 0x01, 0x09, 0x00, 0x13, 0x2f, 0x02, 0x26, 0x02, 0x25, 0xd2, 0x1b
Error, Node047, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node047, Removing current message
Detail, Node047, Notification: Notification - TimeOut`
