First issue:
I have several “aeotec ZW075 Smart Switch Gen5” that I know can report power usage. Unfortunately all of mine only report a static figure (74.8 for the tv one which is turned off - on openhab 2 it reports around 3 for power usage in this state)
Second issue:
I have two Aeotech DSC18103 Micro Smart Switch (2nd Edition) wall switches (connected to lights) that I can turn on through hass but don’t get updated when turned on at the switch (again this worked for oh2). Both of these devices also only have the following sensors: previous_reading and unknown
I think with these switches the issue is that current values does’t have a sensor for current power usage. For completion this is the information section:
It looks like changing notification status to hail, and clicking on the nodes and selecting refresh node info might have solved most of my issues. I’ll try it for a few days and let you know!
As the first issue seems to be resolved I’ll just mention you should always set appropriate values for power and energy reports, if such parameters are available. If a Z-Wave switch only controls a 9W LED bulb and the threshold is 25W no report will be sent until the node is polled.
Status updates for the Micro Smart Switch are not sent to the Lifeline group (or any other group) by default. You need to set Parameter 80 to an appropriate value. The value 1 (Hail) should work fine.
The parameter mentioned above goes for the new Nano Switch/Dimmer series as well.
I have the same issue with the micro smart switch, the state is not reflected if it is used from the physical switch … can you please help me: where do I find the settings for hail mode? The zwave control panel does not show there are options to configure for this switch, unlike my other zwave nodes?
Exactly. Unlike my other zwave devices that expose config parameters in ozwcp or hass, the microswitch doesn’t show config options. I want to try locating parameter 8 in the config file and see if that will work. Will also post back with Aeotec’s support response if I get further. Good to know its working, just gotta find out where.
Works for reflecting switch state in Hass although the zwave panel and ozwcp don’t show the option. Now off to figure out why the options aren’t visible. Thanks guys!
@kahka
Sounds like exactly what I’m seeing…
Where does that config you mentioned go?
And did you ever figure out why none of those options shows up in the control panel?
That is the service call zwave.set_config_parameter which pushes zwave config changes. I use it for example to change the secondary chime melody on my dome siren, because that feature was not exposed for the siren when I first got it.
Turns out that in my specific case for the switch, it depends on whether the device has full support through OZW,
i.e. how complete your device parameter definition is on OZW. Usually removing and readding the node after a few months worked fine for nodes that have incomplete config parameters, provided this device has received OZW updates in the meantime.
