Zwave JS and Ecolink Door/Windows Sensor
I have migrated over to ZJS but all my window door sensors which are Ecolink DW-ZWAVE2 sensors are showing as Unknown. I have even removed and repaired one to test but it still shows Unknown. In the log when pairing it shows all the correct info like Binary sensor and such but the Node in the integration shows nothing.
I have noticed the same thing.
Is this in the right area to ask for the device to get fixed or is there a specific Zwave JS beta form I should be posting this to? I have over 20 of these sensors and they make up the bulk of my zwave for my alarm system all my other devices worked on JS but I just rolled back to use zwave 1.4 until this works.
Is this the one you are talking about? I only have one of them, but I had no problem pairing to Zwave JS, but I do use the Zwave JS MQTT as a control panel so I can see the device details. What Zwave controller are you using?
I have tried both controllers and neither would show device details about the door sensors. From what I can see the dw-zwave2 and 25 are slightly different models, maybe the 25 is zwave+ and is better supported.
So I noticed the driver was getting hung up on my nodes that were no longer online but didn’t mark them as failed so I just removed all my “failed” nodes so the driver didn’t have anything to get hung up on. I then went to each door sensor and in zwavejs2mqtt I did a node refresh and woke up the sensor which is remove battery for 5 seconds and eventually I had them all added. Such a PITA!
