Zwave JS Devolo door/ windows sensor
I’m new to home assistant. I’ve I an issue adding the devolo door/window sensor. The open /close state is not recognize as it should and show only unknown. Other sensor are ok ( lux, temp ).
Any idea welcome. Thank you.
The entity you’ve highlighted corresponds to the Notification CC reports. According to the user manual, the device uses this to report the door status. Watch the Debug logs and see what is reported when you open and close the door.
Try enabling the disabled sensor that says “Door/Window”, which corresponds to Binary Sensor CC reports. It may be using that instead.
What is configuration parameter 7 set to? That defines whether Notification or Binary reports are sent. Maybe the value is not programmed to the default?
If the disabled entity is working, might be easiest to just use it instead of messing with the settings. You can customize it to report door status in the entity configuration.
Hi Fresncoast,
You’re right: the disabled entity is the one that was getting the open / closed status. I’ve disabled the other one and set it with the right settings and now it report correctly
Thank you very much for your help :slight_smile:
David
