Hello
I have started a blueprint for the scene activation when pressing the only button of The Button by Fibaro:
blueprint:
description: "Create automations for The Button by Fibaro using the Z-Wave JS integration.\n"
domain: automation
input:
fibaro_thebutton:
description: "List of available The Button devices."
name: "Fibaro The Button"
selector:
device:
integration: zwave_js
manufacturer: Fibargroup
model: FGPB-101
key_held_down:
default: []
description: "Action to run when button is held down."
selector:
action: {}
key_pressed_1x:
default: []
description: "Action to run when button is pressed once."
selector:
action: {}
key_pressed_2x:
default: []
description: "Action to run when button is pressed twice."
selector:
action: {}
key_pressed_3x:
default: []
description: "Action to run when button is pressed three times."
name: "Pressed Three Times"
selector:
action: {}
key_pressed_4x:
default: []
description: "Action to run when button is pressed four times."
name: "Pressed Four Times"
selector:
action: {}
key_pressed_5x:
default: []
description: "Action to run when button is pressed five times."
name: "Pressed Five Times"
selector:
action: {}
key_released:
default: []
description: "Action to run when button is released after being held down."
selector:
action: {}
name: "ZWave-JS - Fibaro The Button (FGPB-101) v2021.12.08"
source_url: "https://community.home-assistant.io/t/zwave-js-fibaro-the-button-fgpb-101-v2021-12-08/300945"
condition: "{{ trigger.event.data.device_id == device_id }}"
max_exceeded: silent
mode: single
- event_type: zwave_js_value_notification
platform: event
variables:
device_id: !input 'fibaro_thebutton'
- variables:
command_class_name: "{{ trigger.event.data.command_class_name }}"
label: "{{ trigger.event.data.label }}"
node_id: "{{ trigger.event.data.node_id }}"
property_key_name: "{{ trigger.event.data.property_key_name }}"
property_name: "{{ trigger.event.data.property_name }}"
value: "{{ trigger.event.data.value }}"
- data:
message: "received event from node {{node_id}}: {{ command_class_name }} - {{ value }} - {{ label }}"
service: logbook.log
- choose:
- conditions: |
{{ property_name == 'scene'
and property_key_name == '001'
and (value == 'KeyPressed' or value == 0)
sequence: !input 'key_pressed_1x'
- conditions: |
and (value == 'KeyPressed2x' or value == 3)
sequence: !input 'key_pressed_2x'
- conditions: |
and (value == 'KeyPressed3x' or value ==4)
sequence: !input 'key_pressed_3x'
- conditions: |
and (value == 'KeyPressed4x' or value == 5)
sequence: !input 'key_pressed_4x'
- conditions: |
and (value == 'KeyPressed5x' or value == 6)
sequence: !input 'key_pressed_5x'
- conditions: |
and (value == 'KeyHeldDown' or value == 2)
sequence: !input 'key_held_down'
- conditions: |
and (value == 'KeyReleased' or value == 1)
sequence: !input 'key_released'
