I have installed today Zwave JS (moving with a fresh install after the Zwave deprecated HA environment). I have a lot of Fibaro wallplug. I have succesfully added them. I have two issues:
I cant’ see always the update when I manual switch on the wallplug
I don’t see the Wattage usage back in HA. Everything stays 0, but I see in the logs of Zwave JS this:
I assume you installed the ZWaveJS Integration. What are you using in the Supervisor? ZWaveJS or ZWaveJS2mqtt? Either one will work but the latter gives a better control panel UI.
Thanks, did that already with two of them, but no luck. But I see the wattage back in my log of the Zwjave JS supervisor log. What firmware do you have of the wallplug?
That does not appear to be in the zwavejs database. That is likely your issue.
I think some of the information can be imported from the opensmarthouse database used by openHAB and added to the database for a future update… I have not researched this well though.
EDIT: You said it is in the zwavejs logs so the database is not likely the issue, but an integration one.
Try opening an issue for the zwavejs integration with HA.
This is still not working for me for the newer firmware version of the Fibaro wallplugs…
Fibaro wallplugs with firmware 25.25 do seem to be providing power usage data which is being recorded in HA, but the newer wallplugs with firmware 3.2 are still returning zero values…
Edit: I’ve found that it is two of the wallplugs with firmware 3.2 that are not returning values - three others with 3.2 are working correctly.
I’ve tried re-interviewing the nodes, but this has not cured the problem…
