I have a “DCH-Z120 by D-Link Firmware: 1.18” that is a motion/temperature/Illumination sensor.
It is detected and setup completely. It reports temperature and Illumination, but the motion is not reported.
Looking at zwave js log I see the following: Received a command that contains multiple CommandClasses. This is not supported yet! Discarding the message...
I assume this is the motion detection failing ? How can I contribute information so it’s detected correctly ?
EDIT:
I actually found out that the motion detection was working. There was actually 2 motion detection entities and the one that was working was disabled by default.
I saw the same thing. Some devices show up with a few entities, but the important ones (like a binary sensor for a motion detector) is sometimes disabled by default for some reason. Or some have two binary sensors, but the hidden one is the one that actually works.
I am attempting to move from OpenZWave to Zwave JS. I have managed to get one device in a state that looks OK. I have several DCH-Z110 and a DCH-Z510, none of these work and do eventually give similar messages to yours.
I am concentrating on the DCH-Z510 as this is a mains powered device and so reports more easily. What I have when I start the addon:
23:20:25.407 CNTRLR [Node 002] Beginning interview - last completed stage: RestartFromCache
23:20:25.410 CNTRLR » [Node 002] pinging the node...
23:20:25.447 CNTRLR [Node 003] Beginning interview - last completed stage: ProtocolInfo
23:20:25.450 CNTRLR » [Node 003] querying node info...
23:20:25.730 CNTRLR [Node 002] The node is alive.
23:20:25.733 CNTRLR [Node 002] The node is ready to be used
23:20:25.734 CNTRLR « [Node 002] ping successful
23:20:25.741 CNTRLR [Node 002] ManufacturerSpecificCC: doing a partial interview...
23:20:25.744 CNTRLR [Node 002] VersionCC: doing a partial interview...
23:20:25.751 CNTRLR [Node 002] AssociationGroupInfoCC: doing a partial interview...
23:20:25.758 CNTRLR [Node 002] ZWavePlusCC: doing a partial interview...
23:20:25.764 CNTRLR [Node 002] BinarySwitchCC: doing a partial interview...
23:20:25.766 CNTRLR » [Node 002] querying Binary Switch state...
23:20:43.854 CNTRLR [Node 002] Timed out while waiting for a response from the node
23:20:43.955 CNTRLR [Node 002] Interview stage completed: CommandClasses
23:20:43.958 CNTRLR [Node 002] Interview stage completed: OverwriteConfig
23:20:43.959 CNTRLR » [Node 002] requesting node neighbors...
23:20:44.337 CNTRLR « [Node 002] node neighbors received: 1, 3, 4, 5, 6, 7, 8, 9, 10, 12, 13, 14,
15, 16
23:20:44.338 CNTRLR [Node 002] Interview stage completed: Neighbors
23:20:44.339 CNTRLR [Node 002] Interview completed
I hope this helps you with your issue. I have no evidence that our issues are the same at present nor do I have a fix for my problems I just thought that the extra information may help.
Just to let you know this is not an issue with D-Link sensors either. I am seeing this on all my other sensors, Aeotec and Heiman in the main. The only one that is working is my Aeotec Doorbell.
Thanks but no. After 24 hours still only one additional entity available, all the devices are there but none have even a manufacturer available as the interview is not complete. I am still trying to find out what I am doing wrong, everything works like a dream on OpenZwave. But waiting for a while before I post anything as it has to be something I am going, most devices are on the supported list.
