I had to manually figure this out as well. I suppose it would be appropriate to rename the buttons according to their real-life positioning. I will get to this at some point, thanks for the tip
Went ahead and learned some of the blueprint yaml syntax and corrected the variable issue. Button presses should show up as proper events within the log now, and the undefined variable error should no longer occur.
I just wanted to tell you thank you as I just implemented this shockingly easily into my house. Now with two double presses of the “A” button the applicable room’s accent lights can be toggled.
I know it’s been 3 years, but I had to replace my LZW36 Canopy with the VZM36 canopy and this blueprint has saved me probably hours worth of work.
One question though, how do I get the light up/down buttons to transition the light up in steps. On/off works fine.
