Here is a blueprint for the Inovelli LZW36 Fan controller. The blueprint is a copy of the work done by @jerelabs and @troy, adjusted for the unique buttons and rockers of the fan switch.
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: Inovelli Red Series LZW36 Fan Controller (ZWave-JS)
description: Create automations for the Inovelli Fan/Switch combo
the ZWave-JS integration.
domain: automation
input:
inovelli_fan_switch:
name: Inovelli Fan Controller
description: List of available Inovelli LZW36 dimmer combos.
selector:
device:
integration: zwave_js
manufacturer: Inovelli
model: LZW36
button_a:
name: Button A - Up/On press 1x
description: Action to run, when the button is pressed one time.
default: []
selector:
action: {}
button_b:
name: Button B - Down/Off press 1x
default: []
selector:
action: {}
button_a_held:
name: Button A - Up/On held down
description: Action to run, when the button is held down.
default: []
selector:
action: {}
button_b_held:
name: Button B - Down/Off held down
default: []
selector:
action: {}
button_a2:
name: Button A - Up/On press 2x
description: Action to run, when the button is pressed two times.
default: []
selector:
action: {}
button_b2:
name: Button B - Down/Off press 2x
default: []
selector:
action: {}
button_a3:
name: Button A - Up/On press 3x
description: Action to run, when the button is pressed three times.
default: []
selector:
action: {}
button_b3:
name: Button B - Down/Off press 3x
default: []
selector:
action: {}
button_a4:
name: Button A - Up/On press 4x
description: Action to run, when the button is pressed four times.
default: []
selector:
action: {}
button_b4:
name: Button B - Down/Off press 4x
default: []
selector:
action: {}
button_a5:
name: Button A - Up/On press 5x
description: Action to run, when the button is pressed five times.
default: []
selector:
action: {}
button_b5:
name: Button B - Down/Off press 5x
default: []
selector:
action: {}
button_c1:
name: Button C - Up/Increase (Top)
description: Action to run, when the light rocker is pressed up.
default: []
selector:
action: {}
button_c2:
name: Button C - Down/Decrease (Top)
description: Action to run, when the light rocker is pressed down.
default: []
selector:
action: {}
button_d1:
name: Button D - Up/Increase (Bottom)
description: Action to run, when the fan rocker is pressed up.
default: []
selector:
action: {}
button_d2:
name: Button D - Down/Decrease (Bottom)
description: Action to run, when the fan rocker is pressed down.
default: []
selector:
action: {}
source_url: https://github.com/cree8/inovelli_switches/edit/main/blueprint_lzw36.yaml
mode: single
max_exceeded: silent
variables:
device_id: !input 'inovelli_fan_switch'
- platform: event
event_type: zwave_js_value_notification
condition: '{{ trigger.event.data.device_id == device_id }}'
- variables:
button_id: '{{ trigger.event.data.property_key_name }}'
press_count: '{{ trigger.event.data.value }}'
device_name: !input inovelli_fan_switch
- service: logbook.log
message: '{{ button_id }}'
message: '{{ press_count }}'
message: '{{ device_name }}'
- choose:
- conditions: '{{ button_id == "002" and press_count == "KeyPressed" }}'
sequence: !input 'button_a'
- conditions: '{{ button_id == "001" and press_count == "KeyPressed" }}'
sequence: !input 'button_b'
- conditions: '{{ button_id == "002" and press_count == "KeyHeldDown" }}'
sequence: !input 'button_a_held'
- conditions: '{{ button_id == "001" and press_count == "KeyHeldDown" }}'
sequence: !input 'button_b_held'
- conditions: '{{ button_id == "002" and press_count == "KeyPressed2x" }}'
sequence: !input 'button_a2'
- conditions: '{{ button_id == "001" and press_count == "KeyPressed2x" }}'
sequence: !input 'button_b2'
- conditions: '{{ button_id == "002" and press_count == "KeyPressed3x" }}'
sequence: !input 'button_a3'
- conditions: '{{ button_id == "001" and press_count == "KeyPressed3x" }}'
sequence: !input 'button_b3'
- conditions: '{{ button_id == "002" and press_count == "KeyPressed4x" }}'
sequence: !input 'button_a4'
- conditions: '{{ button_id == "001" and press_count == "KeyPressed4x" }}'
sequence: !input 'button_b4'
- conditions: '{{ button_id == "002" and press_count == "KeyPressed5x" }}'
sequence: !input 'button_a5'
- conditions: '{{ button_id == "001" and press_count == "KeyPressed5x" }}'
sequence: !input 'button_b5'
- conditions: '{{ button_id == "003" and press_count == "KeyPressed" }}'
sequence: !input 'button_c1'
- conditions: '{{ button_id == "004" and press_count == "KeyPressed" }}'
sequence: !input 'button_c2'
- conditions: '{{ button_id == "005" and press_count == "KeyPressed" }}'
sequence: !input 'button_d1'
- conditions: '{{ button_id == "006" and press_count == "KeyPressed" }}'
sequence: !input 'button_d2'
