ZWave-JS Inovelli NZW30S
Using the new Zwave-JS this blueprint configures automations for the generation one NZW30S switches from Inovelli.
Please note that this blueprint does not specify Inovelli as the manufacturer for the selector as there seems to be some weirdness in the ZW config files / actual names for some of these earlier Inovelli devices.
Thanks to @troy and @kylerw
blueprint:
  name: Inovelli NZW30S Switch (ZWave-JS)
  description: Create automations for the Inovelli NZW30S Switch using the ZWave-JS integration.
  domain: automation
  input:
    inovelli_switch:
      description: List of available Inovelli NZW30S Switch.
      selector:
        device:
          integration: zwave_js
          model: NZW30S
    button_a:
      name: Button A - Up/On press 1x
      description: Action to run, when the button is pressed one time.
      default: []
      selector:
        action: {}
    button_b:
      name: Button B - Down/Off press 1x
      default: []
      selector:
        action: {}
    button_a2:
      name: Button A - Up/On press 2x
      description: Action to run, when the button is pressed two times.
      default: []
      selector:
        action: {}
    button_b2:
      name: Button B - Down/Off press 2x
      default: []
      selector:
        action: {}
    button_a3:
      name: Button A - Up/On press 3x
      description: Action to run, when the button is pressed three times.
      default: []
      selector:
        action: {}
    button_b3:
      name: Button B - Down/Off press 3x
      default: []
      selector:
        action: {}
    button_a4:
      name: Button A - Up/On press 4x
      description: Action to run, when the button is pressed four times.
      default: []
      selector:
        action: {}
    button_b4:
      name: Button B - Down/Off press 4x
      default: []
      selector:
        action: {}
    button_a5:
      name: Button A - Up/On press 5x
      description: Action to run, when the button is pressed five times.
      default: []
      selector:
        action: {}
    button_b5:
      name: Button B - Down/Off press 5x
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zwave-js-inovelli-nzw30s/280868
mode: single
max_exceeded: silent
variables:
  device_id: !input 'inovelli_switch'
- platform: event
  event_type: zwave_js_value_notification
condition: '{{ trigger.event.data.device_id == device_id }}'
- variables:
    button_id: '{{ trigger.event.data.property_key_name }}'
    press_count: '{{ trigger.event.data.value }}'
- service: logbook.log
    message: '{{ button_id }}'
    message: '{{ press_count }}'
    message: '{{ zwave_device }}'
- choose:
  - conditions: '{{ button_id == "002" and press_count == "KeyPressed" }}'
    sequence: !input 'button_a'
  - conditions: '{{ button_id == "001" and press_count == "KeyPressed" }}'
    sequence: !input 'button_b'
  - conditions: '{{ button_id == "002" and press_count == "KeyPressed2x" }}'
    sequence: !input 'button_a2'
  - conditions: '{{ button_id == "001" and press_count == "KeyPressed2x" }}'
    sequence: !input 'button_b2'
  - conditions: '{{ button_id == "002" and press_count == "KeyPressed3x" }}'
    sequence: !input 'button_a3'
  - conditions: '{{ button_id == "001" and press_count == "KeyPressed3x" }}'
    sequence: !input 'button_b3'
  - conditions: '{{ button_id == "002" and press_count == "KeyPressed4x" }}'
    sequence: !input 'button_a4'
  - conditions: '{{ button_id == "001" and press_count == "KeyPressed4x" }}'
    sequence: !input 'button_b4'
  - conditions: '{{ button_id == "002" and press_count == "KeyPressed5x" }}'
    sequence: !input 'button_a5'
  - conditions: '{{ button_id == "001" and press_count == "KeyPressed5x" }}'
    sequence: !input 'button_b5'
Edit: updated zwave_js_event → zwave_js_value_notification
Kinda novice here, but i cant get this blueprint to work.
here is my created automation using the blueprint:
- id: '1620854772685'
  alias: Inovelli NZW30S Switch (ZWave-JS)
  description: ''
  use_blueprint:
    path: hanerd/zwave-js-inovelli-nzw30s.yaml
    input:
      inovelli_switch: 2e285be95afadc3feb7801e978449cf6
      button_a2:
      - type: toggle
        device_id: ce26f3e5f0073ac620b7f9568d05da90
        entity_id: switch.hall_lights
        domain: switch
here is what I see in the Z_Wave JS log when I double press the up button 2x :
2021-05-12T21:41:39.489Z CNTRLR « [Node 002] received CentralScene notification {
                                      "nodeId": 2,
                                      "ccId": "Central Scene",
                                      "ccCommand": "0x03",
                                      "payload": "0x938002"
or what I see in Z-Wave JS to MQTT:
2021-05-12 15:23:26.943 INFO ZWAVE: Node 2: value notification: 91-0-scene-002 3
but nothing happens
For anyone with the same issue, the fix for me was changing the event type to: zwave_js_value_notification
Thank you both for sharing this. The zwave_js_value_notification update also fixed this for me.
