Hi.
My configuration was running fine on RP3, but now I’'ve restored on a RP4 and got this error:
Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed (‘172.30.33.3’, 3000)]
I’ve reconnected the USB Zwave module and it is running fine:.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[18:28:55] INFO: Both ‘network_key’ and ‘s0_legacy_key’ are set and match. All ok.
[18:28:57] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:28:58] INFO: Successfully send discovery information to Home Assistant.
2022-07-06T16:29:01.014Z DRIVER
The same configuration run correctly in a VMware VM…
So why does it not run on my raspberry 4 ??
Any help welcome.
Z-Wave JS : Current version: 0.1.64
Configuration of the zwave device on my RP3 :
/dev/serial/by-id/usb-0658_0200-if00
Configuration RP4:
device: /dev/ttyAMA0
log_level: info
s0_legacy_key: 6291E1D5C5F***************
s2_access_control_key: E07**********
s2_authenticated_key: C4******************
s2_unauthenticated_key: 5D4***************
network_key: 6291E1D************************
Home Assistant Core 2022.6.7
Home Assistant Supervisor 2022.06.2
Home Assistant OS 8.2
