A few days ago my Z-wave network stopped working and I can get it back up and running, but within a few hours, the Z-wave JS integration says failed, and will try to reconnect. If I restart the addon, it’ll start working again for a few hours, then end up back in the same loop of crashing. It may have been coincidental, but I added a RTL_433 addon and SDR Dongle to try pick discover a RF device that I have, with no luck, then I noticed shortly after my Z-wave network was down. I ultimately restored a backup of before I started messing with the RTL433 and still having same issue with Z-wave.
My Hardware is:
HA: HA Green
Z-Wave Hub: Nortek GoControl CECOMINOD016164 HUSBZB-1 USB Hub
My Nortek is the combo stick so Zigbee and Z-wave. The Zigbee network is fine, still functioning.
I’ve tried multiple restarts of the addon and as I said above, it’ll start working again normal for a few hours, then back to failing to connect. I’ve tried unplugging re-plugging, rebooting, restarting. I haven’t tried actually turning HA off yet. In the Configuration I set Soft Reset to disabled as something I read recommended, but still ends up same issue. I’ve also ordered the Zooz 800 USB controller, but after tinkering around, I’m starting to think its not the Nortek controller, but just the Zwave JS addon, but I could be wrong. Below is the last thing in the Logs that seem relevant.
2024-05-23T05:04:54.053Z DRIVER Serial port errored: The serial port closed unexpectedly! (ZW0100)
Error in driver ZWaveError: Serial port errored: The serial port closed unexpectedly! (ZW0100)
at Driver.destroyWithMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2899:17)
at ZWaveSerialPort.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1141:15)
at ZWaveSerialPort.emit (node:events:517:28)
at SerialPort.onClose (/usr/src/node_modules/@zwave-js/serial/src/ZWaveSerialPort.ts:36:14)
at Object.onceWrapper (node:events:632:26)
at SerialPort.emit (node:events:517:28)
at port.close.then.closing (/usr/src/node_modules/@serialport/stream/dist/index.js:242:18) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
Closing server...
Client disconnected
Code 1000:
Server closed
[05:04:54] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[07:28:31] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[07:28:38] INFO: Soft-reset disabled by user
The new Zooz 800 Controller will get here today and fortunately I only have like 9 Z-wave Devices that I’m using through the controller, so going around resetting and re-adding to new hub wont be terrible, but I’m concerned that It’ll be all for nothing if its just the Zwave JS addon.
