Hi All, finally bit the bullet on the weekend and moved my ZWave to JS… However, the automation I have for motion detection on my Aeotec has changed and scratching my head on how to resolve - although apologies, I daresay it’s been covered, but I haven’t found the answer yet. The automation trigger used to be:
platform: state
entity_id: sensor.aeotec_zw100_multisensor_6_burglar
to: '8'
But now the sensor is a binary and I’ve tried On/Off, True/False, (and quoted versions of both of those), “Clear”/“Detected” (as it appears in the dashboard, but none seem to work. Core log says:
2021-10-17 21:18:43 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: expected str for dictionary value @ data['to']. Got None. (See /config/configuration.yaml, line 131).
What’s the correct translation for this trigger please - apologies, it should be obvious but I’m clearly having a brain fade moment
