I originally paired to the gen5 without issue before I upgraded to the gen5+ so I doubt that is the issue, can’t say for sure on the GD00Z-5 version as I don’t have any experience on those, also I have since moved away from these units as they were to problematic, like the getting confused if it was open or closed forgetting it has a tilt sensor paired to it, so I can’t rule out the latest update for Zwavejs didn’t break it. I built my own setup using the FortrezZ Z-WavePlus MiMO2+ with wired sensors Seco-Larm SM-4601-L3Q Industrial Wide-Gap Magnetic Contact Switches my Garage doors behave alot better with this setup
Thanks Trenton, I may need to move to something like you have. I appreciate the details you have provided.
I mounted a tilt sensor at a 45 degree angle on the top panel of my garage door. As soon at the door starts to lift it reports open.
https://www.amazon.com/Z-Wave-Plated-Reliability-Garage-TILT-ZWAVE2-5-ECO/dp/B01MRZB0NT
Make sure you’re running the latest zwavejs software and latest HA release.
