anybody have success of using the Zwave JS with the Go Control garage door opener
it sees it but won’t load the buttons to open or close it
I can go into the Zwave-js server itself and do a change of state and trigger the door but HA refuses to acknowledge this is a cover or switch of allow any control of it though is sees is as a sensor
my network key seems to work as my kwickset door locks are working as they should they don’t work without the matching key
as on the zwavejs site they are claiming it is done when I submitted a issue and refused to look at it and the server does not produce any buttons to trigger it, only way to trigger it is to change the state.
according to what I read on Home assistant they have Covers integrated already
Interesting. I added mine secure and it connected and shows everything. Guess I’ll give it another go. Thanks for the response at least now I know it’s user error and not system error.
yup looks like closeness was the issue. Decided to rip them down and move them as close to the stick as possible and they connected with extra entities than before. Also seems the tilt sensors werent playing nice had to remove batteries to get them to resync. Thanks for the help wife will be happy garage door opens for her again lol.
I included it non-securely but the parameters did not show up in Zwave-js.
I then followed your advice and included it securely and so far it works.
Thanks!
I am having trouble with my garage door opening which is a Linear (Nortek) GDOOZ-5. It worked fine with my Vera Edge but now when trying to include in ZWave JS in Home Assistant it refused to fully do so. The node adds but not all parameters show up. For example Group 1 should be automatically added, but is not, so no communication can take place between my Aeotec stick and the opener. I have tried including it every which way with security and without. I have tried including it within inches of the Aeotec stick. No joy. I would welcome any ideas.
Thanks Trenton, I am glad you could get this device to pair for you. I have been using only the Zwave JS app to attempt to pair mine. I have not taken the Aeotec stick to the device but rather removed the device from the garage door opener motor and brought it to my Raspberry Pi 4 where my Aeotec stick is attached. There I tried both secure and unsecure pairing with no luck. I am wondering if I am just between updates to the zwave JS driver? (That was updated just before I tried to do this.)
I don’t have any locks that use secure pairing in my system, so I cannot compare to those… (I have not really trusted them so far.) I have tried to force S0 pairing but that has not worked for me either. Now the Nortek opener version I have is GD-OOZ-5, not GD-OOZ-7 (as shown on the title of this post). I am wondering if my unit is just too old? Also my Aeotec stick is Gen5 not Gen5+. Maybe that is the issue? (I have not been able to find a Gen5+ to buy!
