I have a problem with my zwave system going down after a full reboot of my rpi 4
The log looks like a billion chatting devices on my zwave network looking like a faulty node.
But if i use a backup and go back a day it goes away and everything is ok again.
I have my zwave and usb3.s connection to an extension to keep from interference. But still it is tha same.
3-01-09 10:34:59.266 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.280 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.295 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.346 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.360 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.385 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.408 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.423 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.446 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.448 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.494 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.496 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.508 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.510 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.537 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.539 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.685 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.687 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.712 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.714 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.725 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.728 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.756 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.759 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.771 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.772 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.807 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.809 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.825 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:34:59.835 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.837 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.871 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.874 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.892 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.895 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.907 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.910 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.923 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:34:59.925 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:34:59.940 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.942 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:34:59.952 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:34:59.954 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.006 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.008 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.020 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.022 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.035 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.036 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.050 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.051 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.089 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.091 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.117 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.119 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.131 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.134 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.144 INFO Z-WAVE: Node 20: metadata updated: 49-2-Air temperature
2023-01-09 10:35:00.145 INFO Z-WAVE: Node 20: value updated: 49-2-Air temperature 23.5 => 23.5
2023-01-09 10:35:00.164 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.166 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.203 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.207 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.256 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.259 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.314 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.318 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.327 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.329 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.420 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.423 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.448 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.451 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.464 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.467 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.478 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.479 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.537 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.541 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.564 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.567 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.596 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.598 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.620 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.624 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.633 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.635 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.656 INFO Z-WAVE: Node 6: value updated: 50-0-value-65537 11.92 => 11.92
2023-01-09 10:35:00.668 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.670 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.741 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.744 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
2023-01-09 10:35:00.760 INFO Z-WAVE: Node 20: metadata updated: 49-3-Air temperature
2023-01-09 10:35:00.761 INFO Z-WAVE: Node 20: value updated: 49-3-Air temperature 0 => 0
