Prior to migrating to zwave_js, I had been using an appdaemon app to interface with a mimolite.
In it, I had been setting a device parameter with the following call:
self.call_service("zwave/set_config_parameter", node_id=19, parameter=11, value=150)
With zwave_js, it appears that the interface has changed. Rather than using node_id, the device id needs to be specified instead.
So now I am making my call like this:
self.call_service("zwave_js/set_config_parameter", device_id='f61ad85870bb394b844107e1f3a59e79', parameter='11', value='150')
But this call results in the following in the error log:
021-07-30 14:38:07.494656 WARNING propane: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/appdaemon/threading.py", line 936, in worker
funcref(args["event"], data, self.AD.events.sanitize_event_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/propane.py", line 44, in read_mimolite
File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 197, in inner_sync_wrapper
f = run_coroutine_threadsafe(self, coro(self, *args, **kwargs))
File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 308, in run_coroutine_threadsafe
result = future.result(self.AD.internal_function_timeout)
File "/usr/lib/python3.8/concurrent/futures/_base.py", line 446, in result
raise TimeoutError()
concurrent.futures._base.TimeoutError
When I make the call from Developer Tools / Services / Z-Wave JS: Set as Z-Wave device configuration param, and choose the mimolite device from the GUI form I see this in the HA log with no errors or futther trace:
2021-07-30 08:38:23 INFO (MainThread) [homeassistant.components.zwave_js.services] Set configuration parameter ConfigurationValue(value_id='19-112-0-11') on Node Node(node_id=19) with value 150
Is there something wrong with how I’m specifying params in the appdaemon code?
