HI all,
I just did a migration from a Aeotec zwave stick 5 to a 7. in the poces i lost all my associations, now im trying to redo them but i cant seam to figure it out how.
here is my devices:
Fibaro Dimmer 2:
FIBARO Dimmer 2 allows for the associations of five groups:
1st Association Group „Lifeline” reports state of the device. Main Z-Wave+ network controller should be added to this group. The „Lifeline” group can handle only one device. It is not recommended to modify this group.
2nd Association Group „On/Off (S1)” is assigned to switch no. 1. Sends BASIC command class frame according to the state of the device.
3rd Association Group „Dimmer (S1)” is assigned to switch no. 1. Sends MULTILEVEL SWITCH command class frame. Allows sending dim/brighten command to associated devices.
4th Association Group „On/Off (S2)” is assigned to switch no. 2. Sends BASIC command class frame according to the state of the device.
5th Association Group „Dimmer (S2)” is assigned to switch no. 2. Sends MULTILEVEL SWITCH command class frame. Allows sending dim/brighten command to associated devices.
The device to be controlled is a Aeotec Smart Dimmer 6:
Here is what I Did:
I used the Zwave JS UI addon
But It Did not work.
Any guidance on where I went wrong and any help would be appreciated
Thanks all!
